After run oil came out from front bearing (clutch side)
Hi Sir,
Does somebody know why after run oil came out from front bearing (clutch side) of my Novarossi S21WCS09 Kangaroo engine. Is it front bearing problem? Please advise.
Thank you.
Thank you.
That is normal when a lot of oil is used.
If the engine is running fine and with some visable inspection you can't see there is something wrong then it is OK.
If you look carefully, you will see that the front bearings of onroad motors are NOT sealed. So of course, oil can seep out. Completely normal.
