GM genius 90 (2010)
GM genius 90 (2010)
Hi,
looking for a bit of help with my gm 90, i run stock (10.5 and 13.5) and have tried each of the stock standard profiles that come as standard in the speedo with the 11.1 firmware update. the main problem i have is that using modes 6 or 7 the car lasts the 5 minutes fine but is rather slow in terms of straight line speed and laptime regardless of gearing up or down, then when using modes 8 or 9 the car is quicker but regardless of what i do gearing wise it will not run any longer than 3-3 and a half minute (thermal cut off kicks in)
can someone also tell me if the gm 10.5 with the 1600 gauss rotor is timed at 0 as standard or at 30 as has been suggested in various other forums?
