Losi XXX-S
Originally posted by Randy Caster
Yes I have, but after trying it I found I prefer softer springs to get the suspension to work, the flexible chassis seemed a hair unpredictable actually. I do still run a milled chassis but have not cut all the way through the carbon, so it still retains most of the stiffness.
The Evicerator
Remember: The same springs on a heavier car will act softer than they will if they are on a lighter car... that could explain the "squirly" feel you experienced
Originally posted by HarshGuy
Now that's interesting, I bought a milled out chassis from someone and tried it on friday, used the same exact setup as on my non milled car and it was way squirely, I though it was because of the 3.5 less ounces, but now maybe you're making me think it was the flex???
if anyone is really ambitious, you could try this....
Here's pics of it:
I like Todd Hodges mill job it is sweet
Hey Randy I was thinking the same thing it has been quiet in here Anyway I little info on me I went mod at the local track for the first time this last weekend tried both a 10x1 and a novak brushless ss58000 I LOVE my brushless but for performance reasons I think I am going to have to go for the brushed motors also put in my black belt it is awsome. Next step trying to copy Todds Milling on his Chassis
harshguy,
looks great. dude how much weight is taken off or whats the total weight of the car with body,tires,esc,servo and batt?
[QUOTE]Originally posted by HarshGuy
[B]Here's pics of it:
DAMN, that thing is frigg'n awesome; makes me want to keep my Losi. DAMN, I'm still droolin'. Where can someone get that done?
- jAyBeE
- jAyBeE
I have a question I run on a small tight track 100x50 feet a one-way doesn't work but I have heard about spools what do they do exactally and would anyone sugest running one on a track like the one I run on??? thanks
is your track asphault? I've grown to like running spools. They give you awesome rip coming out of the corners but you loose a little lowspeed steering. But you make some setup adjustments to gain more steering. Check out Todd's thread, he's got an awesome setup from the Reedy race on there for a spool.
yeah I am running on a parking lot track, no one at my local track has ran spools that I know of I would like to try it I think any segestions on what spool to use the only one I have really looked at is the I.R.S one. thanks jkerr
I built mine with steel outdrives and JB Welded them onto a 41 tooth pully. The 41 tooth pully is one of the things that will help you gain turn in with the spool.
I don't see why Losi doesn't make a spool. It would be a lot easier to design and produce one of those than a ball diff or a one-way.
