Like Tree2Likes
Losi XXX-S
Old 01-06-2004, 12:13 PM
  #8371
pro3racer.. Your setup looked to be a little soft. Heres what I would do.. Run your 50wt oil all around, 55 (orange) in front, 56 (red) in the rear. Orange front springs, White rears. For tires, Jaco Purple/orange in front and Purple in the back. If you need a full out setup let me know, or, just check out Todd's snowbirds setup from last year. As for the belt, mine moves around a bit too, nothing to worry about.
If you have more questions post them and i'll get back to you next Monday as i'm leaving for the Novak race right now.
Bobby Flack is offline
Old 01-06-2004, 12:55 PM
  #8372
The Evicerator
Default Belt Wandering
Actually, you want your belt to be "wandering" from side to side slightly... this denotes that the belt is not being pulled into the guides of a pulley somewhere ... which means your drive train is more free than if it's "stuck" against one side or the other....
Steve Weiss is offline
Old 01-06-2004, 02:43 PM
  #8373
pro3racer's Avatar
thanks bobby, oh boy, taking the shocks off again, i need some quick release thing over here, lol. I was going to do the 50 all around, but the pistons are opposite for me, oh great. Still got over a week though. Good Luck to Team Losi at NOVAK!!!!!!!!!!!!!
pro3racer is offline
Old 01-06-2004, 09:26 PM
  #8374
Trader Rating: 16 (100%+)
Smile JR XS-3 Radio Settings for Losi XXX-S
All,
I am interested in communicating with someone about our radio settings for a JR XS-3 transmitter controlling an XXX-S Graphite Plus. Currently running on carpet in Sportmans Stock using an RX300 receiver, Airtronics 94357Z servo, Monster Pro motor, and LRP ESC. Any interest? Thanks.
Still Bill is offline
Old 01-06-2004, 09:32 PM
  #8375
JitsuGuy's Avatar
Default Pic of my Car!
Here it is!
JitsuGuy is offline
Old 01-06-2004, 09:48 PM
  #8376
dpaton's Avatar
Default Re: JR XS-3 Radio Settings for Losi XXX-S
I run mine straight up. A little trim here and there, and I keep my throttle deadband near zero, but other than that, I don't use any of the expo or other toys.
But that's just me.
-dave
dpaton is offline
Old 01-06-2004, 10:05 PM
  #8377
Thanks Dave.
I was just playing with mine this evening and found that everything was fairly straightup too; except that both deadbands on the XS-3 were set to 50%. They are now at 0% because it is too on/off in forward and minimal for brakes. Thanks for your thoughts.
Old 01-07-2004, 07:46 PM
  #8378
highwayman's Avatar
what's the lowest ride height you can attain with the 1.15" springs in front?
I have the greens now and i don't have a problem with lowering the ride height.
highwayman is offline
Old 01-07-2004, 09:32 PM
  #8379
RCGaryK's Avatar
RCGary-Try raising the roll center blocks .020" and then run the 4F block in the high roll center holes. That should hook up the rear end more. Also use 55 pistons in the front and 54 in the rear. That is very important on carpet with rubber tires. The bigger hole piston gives you more grip.
This was from Todd a few day ago if you scroll back. It should read the 4R block, not the 4F, and these are rear changes if you guys care to try it. I got rid of most of the push when I did this, I just need to smooth out my driving now. Hard to get a feel for lap times with mod, 19T, and Stock foam out there with you.
RCGaryK is offline
Old 01-07-2004, 09:49 PM
  #8380
RCTech Member #2
TSR6's Avatar
heh...
Gary, It looks like your running quite a bit of kickup...
TSR6 is offline
Old 01-07-2004, 09:50 PM
  #8381
RCGaryK's Avatar
THank you Captain Obvious ROFLMAO
RCGaryK is offline
Old 01-07-2004, 09:53 PM
  #8382
RCTech Member #2
TSR6's Avatar
No Prob. - Although I was only paraphrasing your favorite driver, I can't take any credit on this one.
TSR6 is offline
Old 01-07-2004, 09:56 PM
  #8383
RCGaryK's Avatar
Well, Dale Jr. and Jaques Villeneuve never said that, so I don't know who you are refering to hahahaha
RCGaryK is offline
Old 01-07-2004, 10:02 PM
  #8384
RCTech Member #2
TSR6's Avatar
If only I had a printer...
I would love to bring a copy of this thread to the track tomorrow...
TSR6 is offline
Old 01-07-2004, 10:48 PM
  #8385
JitsuGuy's Avatar
Hi all, if I run a sway bar in the front, will that tighten up the tail end some?
Thanks DUDES!!!
J
JitsuGuy is offline
