Losi XXX-S
#8297
i have also found that layed down shocks will give you more weight transfer, but i have found that the further you lay them down the more the weight transfer becomes side to side transfer(side bite) rather than a forward-back transfer.
#8298
so that would help on a tight track, when your turning more often. I read in the setup sheets, rear toe, is that just from the pivot selction? Still wonderin bout that spool thing.
#8299
Originally posted by pro3racer
I read in the setup sheets, rear toe, is that just from the pivot selction? .
#8300
gotcha, i gotta start stocking up on hubs now, oh boy, nother trip to the store, knew i forgot something today.
#8301
pro3racer, the 1/2 degree toe in hubs for the rear are most often used on low bite surfaces, if your track is high bite you may not need them. On high bite tracks the extra toe in scrubs off or slows you down on your straight away speed. I run them a lot because we run on a concrete surface that doesn't have a a lot of traction.
racer-oZ
racer-oZ
#8302
Originally posted by James Nguyen
Clint - I'll be there. What shock setup were you running on your car?
Todd - Thanks a lot. That was a great explanation. Do you have any input on when to run the steering rack in the forward position or forward flipped instead of in the back position?
50wt oil
blue springs in front
silver in the rear
#8304
question
on the rear arms of the g+ there are two mounting holes for the rear hub. If I use the outer hole the cvd is almost outside the outdrive, and using the inner hole makes the cvd in perfect position inside the outdrive.
question is:
if I use the outer hole to mount the rear hub, is the cvd prone to popping out?
and
fixing my electronics in the car, are there no balance problems in this car, since all my electronics are small?
question is:
and
#8305
Re: question
question is:
and
question is:
and
#8306
Re: Re: question
Originally posted by IMPACTPLAYR
Slow down there.... the outer holes are for different hubs, you CANNOT use those hubs in the outer hole....
#8307
Regional Moderator
lem, you can borrow mine. Text me when you're near QC area.
#8308
Re: question
i use the 1 degree standard hubs in the rear
i don't think so... and you can always tweak the car.
#8309
Got it now
the other arm has 2 holes for the rear hub and the other has 1,
i guess it was installed that way to make it look normal.
need new rear arms to make the cvd fit right into the outdrive.
#8310
the prevous owner of your kit must have used different arms ... get the standard rear hubs...
