Like Tree2Likes
Losi XXX-S
Old 06-04-2003, 12:09 PM
  #6316
SlobbaTech's Avatar
On my car when running 4* anti-squat in the rear or maybe even 2* I had to unscrew the shock bottom some and/or take an old clamp style spring collar to act as a spaced on the rear body from running out of threads. That was on carpet with tires smaller than 60mm, so it might not be much of a problem with the bigger rubber tires.
SlobbaTech is offline
Old 06-04-2003, 01:34 PM
  #6317
Is there anything wrong with running the stock XXX-S wheel nuts? If I should change them, which ones should I get? Thanks
M Ignacio is offline
Old 06-04-2003, 01:39 PM
  #6318
Madcap Magician's Avatar
Nothing really wrong with using the stock nuts, but the low profile nuts are lighter and thread on all the way. They are better especially if you are using foam tires with wider hex-hubs.
Madcap Magician is offline
Old 06-05-2003, 07:10 AM
  #6319
GKC
GKC's Avatar
Are there any difference for the spindles that come with the different degree front carriers?
GKC is offline
Old 06-05-2003, 08:08 AM
  #6320
LouisB's Avatar
not that I'm aware of
LouisB is offline
Old 06-06-2003, 01:06 AM
  #6321
HarshGuy's Avatar
Wow ..I didn't realize that 6 of the 10 cars in the A main at the Speedworld cup were Losi's (and I was there LMAO!!):
http://www.teamlosi.com/results/2003/speedworld.htm
HarshGuy is offline
Old 06-06-2003, 03:08 AM
  #6322
None. Kind of a waste when you buy different degree c hub and ended up al many spindles.
ongbenghui is offline
Old 06-06-2003, 04:08 AM
  #6323
highwayman's Avatar
i agree... that is why im thinking of getting alumunum ones...
highwayman is offline
Old 06-06-2003, 04:37 AM
  #6324
STLNLST's Avatar
Trader Rating: 32 (100%+)
Harsh- I told you guys that Speedworld was the 2nd home of the losi....LOL I did finish in front of the only two SD's that made the main
STLNLST is offline
Old 06-06-2003, 06:27 AM
  #6325
HarshGuy's Avatar
Yea 2nd home of the Losi for sure! ...those SD's didn't look very consistent at all, I know the "SD Sorority" was saying that it's new and it needs to have the kinks worked out, but I remember when the Losi first came out and we picked it up at SWR, it had problems with castor blocks and arms breaking (don't they all when they're new ) , but it's been consistent as all getgo since the beginning.
BTW - you drove your a** off!!!! Killer you made the A, you didn't have to race the "lower mains" with us mere mortals
HarshGuy is offline
Old 06-06-2003, 02:36 PM
  #6326
hey impactplayr are going to rco tommarow it is going to be my first time going
pro3user is offline
Old 06-06-2003, 03:32 PM
  #6327
its pretty cool seeing our names on the losi site!! Crabtryee and I battled all three mains it was to much fun!!
bigdog is offline
Old 06-06-2003, 03:36 PM
  #6328
STLNLST's Avatar
Harsh- My first time out with the Losi I won the mod class at Ripon with Matt Howard in attendance. Every car has breakage problems when they first come out BUT....the Losi has always been consistent. I can't say the same for the Yok. Not bashing just giving my opinion.
STLNLST is offline
Old 06-06-2003, 03:53 PM
  #6329
Ortiz's Avatar
I won stock my first time out with it.. Been in the top 3 95% of the time. STLNLST, hey you going to the nats in NC??
Ortiz is offline
Old 06-06-2003, 06:25 PM
  #6330
Pro3user- as of right now everything is a go for RCO....I will be running a silver Losi alfa body..... and probably the only guy with a KO Mars ex-1 radio...LOL Look me up!!!
IMPACTPLAYR is offline
