Losi XXX-S
#6301
Thanks a lot to everybody! I see that the "air gap" is matter of discussion for all...Anyway I will try both the solutions (with no air gap and with a lot of) on the track, I believe vent holes can help, and possibly careful driving!
#6303
wats the advantage of this car over the yokomo sd n tb evo3 n trfm2?
#6304
it's very strong and doesn't get tweaked.
#6305
it also finishes races. Just like every other car when it first came out it had a few bugs but they were addressed and the car a better because of it. The SD is an improvement over the SP (I'm being told) but IMO the car still isn't as consistent as the Losi. If your car is dialed one weekend and you race that same track with the same layout the following weekend the car should work right????? I'm not seeing that with the Yok. That has always been the case with Yok. When the car works it's hard to catch with a good driver behind the wheel. I'd lay off of the SD for about another two months so that some of the bugs are worked out.
#6306
Got the right shock bodies and shafts on the rear. I'll double check the droop screws when I get home from work. Which I should do because I just rebuilt the shocks.
Another question. We used to run the Street Weapon and Yoks with 60-80 wt shock oil. 35/30 seems awefully light in the XXX-S.
Can someone explain why the lighter oil.
Ned
Ned
#6307
Tech Legend
Trader Rating: 51 (100%+)
I agree with STLNST that the Yok is more inconsistant. From experiance I run at an indoor asphalt track and my XXX-S G+ works the same everyweek no matter what the temp of layout is. My Yok was fast but every week I would have to mess with it a little to keep it fast and consistant. If I had to change foams to another set it was worse even if they were the same compound tires. I really like the new SD but I think I would wait a little to see if they make some minor changes to make it more of a consistant car.
We had two guys show up last week with the new SD and it is a nice looking car and worked fairly well. The guys liked them but said the same thing that they were inconsistant but when working were pretty fast.
#6308
wats bad about the xxx-s g+?
#6309
Double checked the shocks to make sure the long shafts were in the long bodies, OK.
Lengthened the shocks to no effect. I'm starting to thing the oil is just to thin to hold the car up. I'm running an old Teking 411-G2 which is pretty big and heavy for today's standards.
Ned
Ned
#6310
NO if he did mix them up his ride hieght problem would be in the front. Ive never heard of people having problems with rea ride height!?
#6311
sorry i didnt read ahead
#6313
Ned
Ned
#6314
Rear ride height....
I had a similar rear ride height problem. I had a hard time getting 5mm on my setup board so I switched to 1.15" rear springs. That fixed the problem but I also noticed that it only appeared on a freshly built car and seemed to get better after I ran it a few times.
Good luck.
Good luck.
#6315
Since I always start with the box setup I haven't actually tried the heavier oil yet. There are no racing oriented LHS's in the Austin area so I will have to start with the kit springs.
Shock setup is such - front: 35 wt, purple springs
rear: 30 wt, silver springs
I chose the oil based on the Ready setup. Also, our track is not located near a LHS so this first weekend will be based on what I got.
Ned
Ned
