Losi XXX-S
#6286
Arms front and rear
Bumpers Front and rear
Spurs
Rear hubs (standard and off-set, 0 and 1/2deg.)
C-hubs 4 and 6 deg.
Maybe a set of shock towers front and rear
I also bought a set of diff pulleys, and will be getting the parts to build 3 diffs 2 standard and 1 overdrive, and 2 spools 1 standard and 1 overdrive.... This way I never have to build or rebuild one at the track.....LOL
Spurs
C-hubs 4 and 6 deg.
#6287
TakeOff CS 27 Tyres
Hi everybody,
it's the first time for me on this thread, and I have a real big problem: as you see I'm from Italy and here the temp is so hot now that when we race the TakeOff CS27 (only legal tyre for our Championship) and the asphalt gets more than 40°C, the XXX-S starts to be undrivable because the tyres get too hot! My team mates have the same problem.
I know there are some rims and inserts that can help to leave them cooler ( with "air gap effect" ). Can you explain this and suggest some insert/wheel combination ? Our competitors (X-Ray, Asso and Corally Teams) seem to know pretty well how to use these tyres, since they suffer a lot less for that!
Many thanks in advance!
Eddi.
Eddi.
#6288
Re: TakeOff CS 27 Tyres
Originally posted by EddiRossi
Hi everybody,
Eddi.
Hi everybody,
Eddi.
#6289
Well you could steal theirs and see what inserts are inside!
The larger the air gap the more heat in the tyres, so you could try some inserts like Sorex As which fill more of the tyre
I'm not an expert in hot conditions because it's always cold here.
#6290
With the track temp you guys should talk to the race director and explain that the whole reason for controled tires is so you dont have problems like your having,whats the point of controled tires if they have no control of rims and inserts.Where I race at 40c track temp is about what we have in april.. Right now our track temp is around 135 f to 145 f(60c to 70c) and the tires we run are 40s in the day and 36s at night,right now the temp in the shade is 45c (outside temp).One last thing from what I understand the air gap between the insert and the tire heats the tire up more not less,I would try a harder insert instead of a softer one.and i dont think i would use any traction compound.
#6291
Trader Rating: 32 (100%+)
More Air gap will help keep your tires cooler. When you have more air gap your tires will heat up faster but will stay at a cooler temp then the same tire with a fuller/less air gap combo. Your insert gets hot too and when you have less air gap its pressed against the tire keeping heat in the tire. With more air gap more air can move around the inside of the tire keeping it and the insert cooler. Now if your insert is too soft and causing the tires to deflect too much that might be a problem but more air gap will help keep your tires cooler.
#6292
You learn something new every day, I'll stick with my CS22s
#6293
Re: Spare Parts
Originally posted by aviaar
What are the best spare parts to have for the XXX-S?
#6294
Hi everybody,
Eddi.
Hi everybody,
Eddi.
#6295
chef88- I had the same problem at the Norrca Nats a couple of weeks ago. I bought a IRS spool and it was tight thanks to MDawson I was able to run the losi spool by putting in a thicker pad and the losi spool worked great.
MDawson- by the way what are those pads made out of anyway.
#6296
unobtainium spool pads. glad it worked for you.
#6299
Originally posted by xxxkat
Long time no hear from Clint,You racing the Cup today,If your racing good luck,And would you please beat Mo & Matt..
