Losi XXX-S
#5566
I am pretty cheap, and im on a budget. So i might jsut stick to my standard servos until i break em (i never broke one soooo far).
thanks for all the help
The speedo i have is the Novak Explorer 2, what high performance race speedo should i look into?
Sorry for all the questions, im a noobie to racing.
Thanks! I would be nowhere without you help.
#5567
TOO MANY QUESTIONS
"Sorry for all the questions, im a noobie to racing."
KevanB
dont apologise, asking questions is how we all learn this RC stuff
KevanB
#5568
Losi Spring Rates
Hicheef, here are the spring rates:
A5117 White 7.6 lbs
A5118 Orange 8.6 lbs
A5119 Yellow 9.6 lbs
A5120 Pink 10.6 lbs
A5121 Red 11.6 lbs
A5123 Silver 12.6 lbs
A5125 Blue 14.6 lbs
A5126 Green 17.5 lbs
A5108 Purple 20.0 lbs
A5110 Black 25.0 lbs
A5112 White 30.0 lbs
A5114 Orange 35.0 lbs
A5115 Yellow 40.0 lbs
Hope this helps.
A5117 White 7.6 lbs
A5120 Pink 10.6 lbs
A5121 Red 11.6 lbs
A5125 Blue 14.6 lbs
Hope this helps.
#5569
Cheap servos are the devil!!!
Dont waste your first few years learning to drive and race with a cheap servo. It is more important to have a high torque-speedy servo than any hot motor, great ESC or the newest best car kit!!! Take it from someone who learned the hard way-cheap servos are a waste!!!!
#5570
Still Getting Wheel Chatter
Hey Guys, I posted this question a month or so back and am still having a problem. When I run diffs in the car the front wheels seem to always make a chattering noise when entering a turn. If I install the one-way it goes away and steering is smooth but I cant always get the rear traction needed for a one-way. I installed rpm ball cups but it didnt seem to help. Anyone else have this problem? Any help or opinions would be appreciated.
Thanks, Blake.
Thanks, Blake.
#5571
You have probably been throught all this then, but
have you already limited your steering throw ?
also, how long since you rebuilt your CVDs ?
#5572
The Cvd's only have 8 races on them and are smooth and free. Reducing the steering throw was one thing that someone recomended to me this weekend. How much should i reduce the throw on the steering? I have been adjusting it so the steering spindle just touches the carrier and then backing it off 2 clicks on my m8, is this to much steering travel? If so, how should i adjust the base steering?
Blake
Blake
#5573
Regional Moderator
Re: Losi Spring Rates
A5117 White 7.6 lbs
A5120 Pink 10.6 lbs
A5121 Red 11.6 lbs
A5125 Blue 14.6 lbs
Hope this helps.
A5117 White 7.6 lbs
A5120 Pink 10.6 lbs
A5121 Red 11.6 lbs
A5125 Blue 14.6 lbs
Hope this helps.
my question is what springs to order? i run carpet very little and more asphalt and smooth surface concrete can you suggest which ones to buy and which ones i should buy 2 sets of for F/R.
thanks for any info
#5580
Todd hodge told me that congo blues are 30lb, congo purples are 35lb and yellows are 40lb.
