Losi XXX-S
#4696
Re: Very angry...
Originally posted by Nightbreed
There is not enough clearence from the front c-spindle to the shock spring.
http://www.teamlosi.com/xxxs_manual/BAG-F-3.jpg
On the front make sure you part 120 installed on the front and part 123 installed on the rear. I don't know what spindle carriers come with the G+ but if they are 0 degree and you have the front arm moved forward they will probably rub. You can fix that by placing a #4 washer on the lower shock mount screw between the shocks bushing (part 110) and the front suspension arm.
If your trying to run anti-dive with 2 or 4 deg spindle carriers in the car you might have to put part 123 on the front shocks tower to get the clearence you need.
The diff bolt on one of the diffs won't even go in far enough to tighen the diff. The other only goes in enough for it to work. I talked to one of the guys at Losi in the tech department and he said just to reassemble it.
Reference Figure 1: http://www.teamlosi.com/xxxs_manual/BAG-A-1.jpg
and to just shave down the cvd to make it fit. You have to be kidding. Very disappointed! Can anyone help. If I have to start grinding on stuff, bye. bye Losi. A.E. I'm back. Jeesh... I so p.o I hoped to start racing this next week. I can see one problem or so, but this many?
#4697
Thanks ChadK, I didn't see your post before I posted. That explains why we can't get any 4 deg hubs in stock for our guys here locally. LOL.
Nightbreed, please do as Chad described also.
If you have any more questions please feel free to ask. That's why this board is so great. With all the experience we all have combined there is a fix to about anything. However we're still pondering why our wives don't like us racing. LOL, that was a joke.
#4698
Tech Legend
for the belt leaning issue, you should recheck the belt tensioner and make sure you pressed the bearing all the way down. I know you may think you did (I did too), but it should snap in hard. I was having the same issue that the belt seemed to want to go to one side of the spur assembly.
#4699
Tech Legend
futureal, thanks for the info. I think I am alittle confused on what exactly you mean but I am reading this in a rush
so basically:
if I want the rear to not stay as planted, i should shorten the link and move the link higher up than the stock setting on the middle row? (using PRP shock towers)
Anyone with experience with the PRPs? What advantages do you gain running really stiff springs on carpet? Does your vehicle react quicker?
so basically:
#4701
Trader Rating: 32 (100%+)
Nightbreed.....I would look at what everyone has sugested to you.....check your lock nut in your diff it might be bad....I have had some come with out any threads on them so you might have one like that....plus they are also alum. and its a very soft alum so they can strip easy. If you need more help we are all here and will help anyway we can.
#4702
If all else fails dood, start wingin' the car into the corners, have faith in the Losi Gods, and let the car do its job. Drive that thing like you stole it and it'll treat you with respect.
#4703
R/C Tech Founder
Also, it's worth noting that I would make those adjustments incrementally. In other words, don't both shorten the link and move it up at once, try one or the other first to get a feel for what it is doing to the car. That is the best (and really only) way to learn how to set up a car properly.
For springs, I see no need to run stiff springs unless you are running foams, in which case the stiffer, the better. Reason being, softer springs add traction at that end of the car (since the suspension is absorbing the forces that would normally cause the car to break traction, or slide), and foam tires have more traction than you'll likely need.
On rubber, I run the car as soft as I can get away with. One of the benefits of this is that the car is less likely to roll over when one side gets picked up off the ground. Either in car-to-car contact, rolling over a corner dot, etc. Since the suspension soaks up some of the lifting motion, it gives the driver an extra split-second to make a correction and get the wheels back on the ground. Once again, this matters to me since I'm an aggressive driver, normally cutting a very tight line and making inside passes and so on.
But to back up a sec, the general idea is that a stiffer spring will give you less traction, but faster side-to-side recovery, and vice versa. So in many cases you want to have a stiffer spring in the front of the car, for faster steering, and a softer spring in the rear, to balance out the steering by offering a bit more traction.
Hope some of that helps, or at least makes limited sense.
#4704
Thanks for the help guys..
I figured I was going to have to shim something. Yes, your right, I have the front A-arms forward and I am using the 0-degree c-spindle. I did not strip the diff nuts, so they must be bad. I wonder if losi will replace my nuts. Does anyone know if Losi has any plans to redesign the one-way or make a new cvd bone just for the one-way? In the old days, I spend much time trying to get parts to fit and I don't like doing it anymore. Today there is no reason for it. Its called competition.
#4705
Yep...
I am using the right parts and the front shocks still won't fit. Went back to losi ball cups. I am using 4degree front spindles and 0-kickup and it don't come close to fitting. I went to the 3rd hole in from the outside and it still won't fit. I moved the arms back and put the spacers in the front blocks and it still won't fit. Back to no room between the cvd and the oneway button head screw. What the $%#$%! Yes, I'm using the right hinge pin blocks. I have been putting models together for years and I have never had problems like this. Any last help? What else could it be?
#4706
Re: Yep...
I did it myself, in a hurry, hacking about 5 minutes before my heat, grabbed the wrong part.
Crap Happens..
How much more space do you need? Where does the CVD bottom out against the screw? How much ride do you have when it finally bottoms out?
-Troy
#4707
Sounds to me like your bearings in the steering knuckles might not be pressed in all of the way if the cvd is right up against the oneway screw. You will have to look at the smallest things even if they sound stupid. I bet it's something little and you're going to slap yourself when you find out what it is. Hang in there though.
#4709
XXXS belt problem
Originally posted by speedmachine
Help Needed!
The belt on my XXXS always get tangled when I brake the car. Tangled as in, the belt ran out of the belt tensioner and jam. I cant seem to figure what is causing the the belt to get spin out of the tensioner. I tried changing to a new belt tensioner, but still the problem exist.
I noticed also my belt seems to be leaning more to towards the outside of the spur gear when moving(towards the arm of the belt tensioner). Could this be the cause?
Appreciate anyone could help and offer any adivce. Thanks!
Help Needed!
I did snap the bearing all the way into the pulley tensioner. I still get the belt leaning to one side, the side towards the metal arm and it's wearing the belt.
Help! It's driving me crazy... & frustrated!
#4710
speedmachine, first you need a new belt, that belt that was tangled has been crimped to hell and back-no good! Secong, you need to make sure your pulley in on the right way meaning the larger lip of that white pulley needs to be on the side closest to the pulley arm or passenger side of the car. I had a friend who installed that piece on backwards and the same thing happened to him.
