Like Tree2Likes
Losi XXX-S
Old 09-22-2002, 06:13 AM
  #3841
Sigearhead's Avatar
Trader Rating: 74 (100%+)
GM3 is a Trinity Green Machine 3 stock motor, it's the stock motor that produces the most RPM's.
Sigearhead is offline
Old 09-22-2002, 06:16 AM
  #3842
senna's Avatar
Unfortunately, everyone has to use the same Corally Stock Motor ...
Is there anything that can be done to such sealed stock motors to go faster?
senna is offline
Old 09-22-2002, 06:51 AM
  #3843
senna's Avatar
Has anyone ever tried to have a final gearing ratio of 4.5 - 5.0 on the LOSI XXX-S ?
senna is offline
Old 09-22-2002, 07:39 AM
  #3844
ausracer's Avatar
ive never geared a motor like that but i cant see why you shouldnt be able to. you may have to put on a smaller spur though.
ausracer is offline
Old 09-22-2002, 08:20 AM
  #3845
i have a new losi xxx-s kit. what parts should i stock ? what parts break easily? does the stock main and inner pivot block mounts break easily? do i really need to upgrade to a graphite chassis?
mmmm is offline
Old 09-22-2002, 08:24 AM
  #3846
PIIHB!'s Avatar
Trader Rating: 14 (100%+)
Hey guys...
Who makes the best aluminum castor blocks for the xxx-s? What's the degree on the stock blocks?
Where can I find the internal gear ratio of the xxx-s? (so I can figure roll-out).
PIIHB! is offline
Old 09-22-2002, 08:25 AM
  #3847
PIIHB!'s Avatar
I've had mine for 1.5 months and only broke a castor block. Then again I don't hit much...
PIIHB! is offline
Old 09-22-2002, 08:28 AM
  #3848
TRF414M's Avatar
This is for 23 turn motor. I tried 5.2 final gear ratio
TRF414M is offline
Old 09-22-2002, 08:38 AM
  #3849
TRF414
what spur and pinion did you use for a 23 turn motor? How's your XXX-S in terms of durability?
mmmm is offline
Old 09-22-2002, 09:59 AM
  #3850
STLNLST's Avatar
Trader Rating: 32 (100%+)
Originally posted by BoLink Boy
Hey guys...
Gear ratio is 1.83 with the stock pully.
1.78 with the smaller 41 pulley
STLNLST is offline
Old 09-22-2002, 11:32 AM
  #3851
senna's Avatar
The LOSI XXX-S comes with 2 identical pullies (front and rear) and an optional smaller pulley.
Where should the smaller pulley be used? Front or rear?
senna is offline
Old 09-22-2002, 12:16 PM
  #3852
LouisB's Avatar
The smaller pulley can be used in both ends to tune the handling. It says what difference it makes in the instructions
I run my car overdriven.
LouisB is offline
Old 09-22-2002, 01:07 PM
  #3853
OBY
OBY's Avatar
Corner Speed
how can i get more corner speed on smooth tarmac tracks, fast sweeping ones, i cant get the hang of them, silly tracks made for nitro cars!!!
OBY is offline
Old 09-22-2002, 01:09 PM
  #3854
senna's Avatar
Just for suggestions ...
What do you think will be a good setup of shock oil and spring hardness (front and rear) for a smooth large asphalt track outdoors with a mixture of corners and long straights ?
senna is offline
Old 09-22-2002, 01:45 PM
  #3855
PIIHB!'s Avatar
OBY-Remember to take the turns a bit wider that you would if you were on a tight indoor track. I raced at a track 2 weeks ago that was 150' x 90' with 15' lanes. I dove in tight in every corner ( I usually race on a tight indoor track) and would lose tons of time every time.
PIIHB! is offline
