Losi XXX-S
#3811
rayhuang - try andrew gray's foam setup for the xxx-s. it is listed on the losi site and works well here in minnesota
#3812
Shock towers
The Team PRP XXXS shock towers are in production and we are now accepting Pre-orders on them. Please check out our site for all of the information including our pre-order deal, http://home.attbi.com/~teamprp/
T. Hodge- send me an email, I can send a pair out to you this week if you'd like to mess around with them before OktoberFAST. [email protected]
Thanks much!
Ben
Thanks much!
Ben
#3813
Originally posted by black-knight
do the xxx-s drive shafts fit the old Street Weapon?
thanks for the tips and info guys!....
#3814
Front Shocks
I have a XXXs that I bought second hand, the guy I bought it from said it has front shock shafts for carpet racing ie .28 in a standard threaded shock body. I have had a look and they are a gold colour but how do I tell if they are standard length or the .28 version?? What does the .28 refer to ??? Can I measure them if so what size should they be?
#3815
shock shaft info.
0.28 refers to the amount the shock shaft moves in and out of body (the throw as it were). I think you could measure that no problem. Should ne 0.28" or 7.1mm I think!!!
Also-if the front shock bodies are shorter than the rear bodies-you have got the short front shock kit on the car. The gold color is a nitride coating to make it harder and smoother. Losi makes a short shock kit that includes those shock shafts and the threaded bodies. I think you are good to go!!! If not-you can buy the bodies. Part #A-5027
To measure-I would put a thin black line on shock shaft at full compressed with a thin Sharpie. Then fully extend it and make another mark. Measure the distance between marks. Lets hope it either 0.28 or 0.36.
If not-sorry!!
If not-sorry!!
#3816
Thanks very much I'll give it a try, I presume then that .28 is the one to go for as I race mostly on carpet
#3817
question
What have you guys seen being uesd to layout a track on carpet?
Are 2x4's or some type of PVC pipe being used? what works best, any ideas are welcome.
Eric
Eric
#3818
Hmmm.... Looks like someone is doing a little bit of research for a nice pretty new track in Tucson...
What up Mr Fike (as in Nike) - how are things going in Tucson??
The wonderful state of Kentucky is... well.... very green... and wet compared to the desert!!!
Any news on the opening of the carpet track?? Or are you going to continue to race at the glitch box?
Wilde
Wilde
#3819
Wilde (are those banjos I hear???:P)
I've been told (heard) that it's expected to be the trhird week of October... and yes I will most likely continue to race at HappyTown. The new asphalt is real nice and smooth mucho, mucho traction. I also hear that the off road is pretty nice... no rocks....
Eric
Eric
#3820
Re: shock shaft info.
Measure the shock when it is fully extended, then again when it is fully compressed. Digital calipers are nice for this Obviously you would then subtract the shorter measurement from the larger to get the ammount of travel.
#3821
course design
Eric F-Don't know if you got an answer to course design already. Your e-mail is turned off. Send me an e-mail for a little description of the pipes to use. John [email protected]. Use 2" PVC with oversize 2"2 inch wood internally with countersunk screws to make the joints. Use 1.5 inch flexible silastic pipe for the curves.
#3822
Registered User
Re: question
Eric
Eric
#3823
Velcro... that seems like a good idea, but what does it do to the carpet in the long run? Also does it withstand the impact from the cars?
John, I'll email you later today.
Eric
Eric
#3824
What they do at Stockton is mount square pieces of wood inside the downspout to connect pieces together. The velcro only holds the assembled track layout to the carpet. There are large pieces of velcro hooks all along the bottom of each piece and they do hold in place very well. After each race, the marshals have to move the heavily hit sections of track back in place, but that's pretty standard.
#3825
TSR6: mmmm hairy bearings!!
