Mugen MRX-4
#1186
mrx4 arrived ..
hey guys
got my mrx4 lastnight .. all the kitpieces look very neat cant wait to finish this machine. ill be buying the os vz-r version 2 for this car as its cheap to buy locally. then when i feel i can drive the car ill get it modified for more power
im coming from 1/10 v one rrr with modified tz engines.
#1187
mugen mrx-4
doode how funny is dat... i just got a mrx-4 too with the vz-r already on it!
#1188
Originally Posted by HarKonnenD
Anyone ran less than 3 degrees of camber in the rear? How did the car perform then? I'm running -1.5 toe in and if I remember -1.5 or 2degree of camber in the rear. The car stays pretty planted though for my track no problem. Would going to 3 really make that big of a difference?
#1189
mrx3
I'm upgrading to a new car....
So just thought I post to see if anyone needed a MRX3 roller.
http://cgi.ebay.com/ws/eBayISAPI.dll...MESE%3AIT&rd=1
Item number: 6048943015
#1190
EFRA Airbox
Sorry, if this is a silly question, but I will take my chances. Are guys running the EFRA airboxes for any particular reason here in the USA? I know they are required over-seas, however I noticed quite a few guys using them, and its not required here unless your club is in an area where they need to keep noise levels to a minimum. One person mentioned they felt the low end being stronger with it on the car, and no noticely negative effects on the top end...
#1191
Lil Paul - not a silly question. I use the INS box amd a 3 chamber pipe (JP 2031) as per our club rules this year. The engine performance seems to be strong throughout the rev range. You'll probably see better fuel mileage with the INS box as well (ie less overall air in at one time, leading to less fuel needed for the same air/fuel ratio).
#1192
hi ron here are your bodies for the vegas race. hope you like them
#1193
wicked
#1194
nice
nice doode i saw the v one rr body shits gnarley
#1195
The newest engines will be designed around these INS-boxes, so the just might perform better with an INS-box.....
#1197
front pivot balls ...
hey guys when screwing in the front pivot balls how much gap are you leaving at the bottom ? im referring to the gap between the hub and lower suspension arm ?
not to worried about the top because ill adjust that when i ste up the camber.
thanks!
John
thanks!
John
#1198
thanks!
John
thanks!
John
#1199
Nice paint job Jeremy.If Ron doesnt like them i will take them.
#1200
Those are sweeet Jeremy
