Mugen MRX-4
#556
Thanks Trashcar for confirming the spring order.
HarkonnenD about those Novamega engines I can not really say anything yet. It's my first 1/8the car (I also run electro cars) and I can not compare the power to another engine. For me it is plenty fast for the moment and the car runs great.
I do know the engines have the reputation here to be a little difficult to tune. For the moment after 3 liters of nitro gone through, no complaints. The car starts beautifully and runs without problems. In a few weeks I am going to compete in my first race and then I will now more.
I am going to buy a higher priced Novarossi motor in the future which will only be used for racing.
You can not beat the price of the Novamega for practice though. If it holds up, it is a great engine for that price.
In respect to roll center I found a great article here
http://www.mytsn.com/publ/publ.asp?pid=9986
The article was written by Glenn Cauley. Be sure to check out his other
articles to because he wrote some great articles.
Spillertwo
Spillertwo
#557
thank you SpillerTwo.
I have allready found that article.
Thanks anyway.
An by the way, we use an MRX-3 receptor protection box to protect our receptor in MRX-4, you could see pictures here.
http://www.cochesrc.com/foros/ftopic42133.html
bye
Thanks anyway.
bye
#558
Hello PMvalente,
I already have the same receiverprotector installed
Looks a little bit safer that way for those expensive receivers.
Also liked the pictures of that red body on the link. Sweet and
simple.
Ciao,
Spiller
simple.
Ciao,
Spiller
#559
Originally Posted by finchy
just wondering does anyone know what to use to adjust the front upper arm height ( front roll centre?). Do you use the same shims used for rear, or is there a specailized part for the front.
Cheers
Cheers
#560
r collins,
is the mtx3 clutch the same as the mrx4? if not, what parts are the same?
thanks.
thanks.
#561
Joe, almost all of the parts are the same:
Differences:
- Flywheel (mtx3 is smaller)
- Gears (mtx3 uses 0.8 pitch gears as option part, stock the gears are the same pitch)
- Spings (both can use the silver / gold sping / JP sping) depends on the track grip
These are the only differences, all other parts are interchangeable. I recommend the drilled light weight flywheel weights for both.
Differences:
#562
thanks carl.
#563
Mike or Robbie,
Can I just buy a set of rear shafts for the rear CVA's? I don't need the entire contents of a rear CVA kit- just the driveshafts. I have a ton of sets left from my MRX3 that are too short due to the longer rear a-arms on the 4.
H0291 is just the standard axles with the drive pins at each end that come with the kit correct?
Will you guys be atending the GLC?
Thanks!
Thanks!
#564
somebody help me about mike swager setup sheet for mrx4.
#565
Steel gears
Hello,
Anybody know where you can get steel 1st gears for
the MRX-4 instead of the stock aluminium gears ?
Thanks,
Spiller
Thanks,
Spiller
#566
Originally Posted by Spillertwo
Hello,
Thanks,
Spiller
Thanks,
Spiller
#568
hello!
can someone tell me what ackerman insert shoud I use (wich on left; A,B,C or D) to get more agressive corner entry and what insert should I use to get most overall steering, since I find my car quite understeered in corner entry and midcorner. corner exit is just perfect!!
TNX!
TNX!
#570
I want a mugen mrx-4. is $500 a reasonable price? which site is the cheapest? can anyone give me info . I want my first car to be fast and big, strong AND FAST. the mugen shows a lot of promise.
anyone gimme a site? can I race this car along with other hpi's or not ...it' is a 1/8th.
