Mugen MRX-4
#1531
Originally Posted by mrgsr
Hi
thanks..im using a novarossi pipe its a 2015 with 3 fin header.
the track has 19 corners and 1 long straght with a sweeper at the end. im thinking of getting the vzr modified to increase the top end. it was cheap to start with..
im trying to find a piston liner for my m-rossi rex pr350 that should have heaps of power to get around.
You definately need to get that motor modified. It's pretty decent, but as always if someone is about your level of skill and has a faster motor they will leave you behind.
#1533
What is a good throttle servo?
#1535
Originally Posted by THE DOCTOR
Futaba 9550 servo
#1536
stiff drive train?? and click sound
hey guys
i just wante dto ask how we can free up the drive train on the mrx4
ive replaced some of the bearings with metal shield and its getting better but it feels so tight still especially with the new rear belt.
i also have a click sound sound every half rear wheel rotation what could this be?
#1537
hey guys
#1539
Originally Posted by quietstorm76
I have the same problem including the clicking sound. I keep checking for a rock or something but there isn't one. I have some Acer bearings and they help alot but still not as free as the 960.
Now you just have to figure out which one is worn. It could be the pulley or hub. If a new pulley is tight on the hub then you are all set. If a new pulley is loose, then you need a hub.
In a pinch I've wrapped teflon or electrical tape on the hub before I put the pulley back on.
#1542
If the belt is already installed, try to sand it while it is in the car.... should be possible when wheels are spinning on your starterbox......
#1543
Originally Posted by cdelong
100% sure your problem is that the brake pulley or brake hub is worn. Take the shaft out and remove the pulley/hub assembly. The pulley will be loose on the hub.
Checking......................
#1545
mrx-4 or mrx-3?
Hey guys,could you please tell me if this car is an MRX-3 OR an MRX-4?I'm new in 1/8 scale ,so i need your help.What are the differences between the two cars and how did you understand if this is the one car or the other?
