Thunder Power 40C puffing
Ive been running these for a while - i have 6 of them
I charge on a TP 1010C with a 210v balancer, always charge at .5 C and always store at 7.8 volts. There has been a couple weeks where i stored 2 of them full charge but now all of them are puffing - I think
How do I tell if they are really puffing. It seems like the case separated really easy. - right now it separates by about 2 -3 mm when I charge and when I run
Is this puffing?
Notice the tops of the packs dont rest flat in the pics
http://i296.photobucket.com/albums/m...rt02/002-3.jpg
http://i296.photobucket.com/albums/m...rt02/001-2.jpg
Is this puffing?
Is this puffing?
Is this puffing?
I had one puff on me before. Not sure how it happend, but I've made sure it won't happen again.
1 of my Fantom has the similar trouble, i just charge it 1 time in days ago, with 5A 1C, then happened this.
I don't know why, but it's still usable.
Good question, Mine have just swelled over time, like I said they have a ton of cycles on them but they're still strong. My older puffed packs run no different than my newer unpuffed packs which i can only assume will do the same thing because every TP pack I have has puffed over time. I just figure I'll continue to get my moneys worth out of them until they are too puffy to strap in the car, and I'm so confident that these packs are still safe that I'd store them under my pillow when i sleep and transport them to the track in my underwear.
My question, "HOW?" was really referring to the person who said he would make sure that never happens again. How would you make sure it never happens again?
I use mine per the manufacturers recommended usage procedures and never charge at more than 1c nor do I run batteries anywhere near cut voltage so I too am curious as to how one could go further and prevent this from happening. As mentioned this isn't an isolated incident with one of my TP packs, they all have done it over time.
If anyone has any questions or problems with your Thunder Power products please contact us at 702-228-8883 or [email protected].
You can also go to http://thunderpowerrc.com/rma.html and fill out the form. We will send you back an RMA number or answer your question.
i have 2 that i have run from late last year and 1 has puffed a bit but still performs well and shows its balanced to within .02v.
it runs great and hasnt had any hassles other than the slightly puffed casing.
its never been discharged below 7v in stock racing and is stored at 7.5-7.6v as well as balance charged.
Unfortunately for me i am not in the US so contacting Thunderpower is not practical as posting it back and the return postage is pricy.
