serio 2013 ????
serio 2013 ????
does anyone have a serio 2013 pipe? i just need to see what the gasket looks like. my pipe looks to have a o ring groove on both the header and the silencer. but i can't find a gasket that will seal. i have tried serio's oring gaskets from a main, oring gaskets from a grp, and several std. gaskets. nothing seems to fit. please help.
Let start with the name it is SIRIO. here is a pic of the pipe and the seal http://www.amainhobbies.com/product_...old-2010-Model This is from Werks also the orion use the same seal, so Sirio should used the same, hope this help.
Yes, I have a sirio 2013, on the engine sirio Evo4 need use some normal gasket, but to the pipe, yes ,need soom slight gasket, from the engine I'm use VP pro. but the slight one, I can't remeber.....
The first model of the 2013 did use a different coupling, some kind of teflon ring was used.
Roelof is right! I completely forgot about those things but when the 2013's were first made they did have some type of white teflon donut/ring thingy between the pipe and manifold. I seem to remember that they only made them like this for 6 months to a year and it was right around 2004 or 2005 when they did this. Hope this helps!
Regards,
Ron
Regards,
Ron
Just use the Associated gaskets, they work great and come 4 to a pack.
