Speed Passion Cirtix Stock CLUB ESC
#841
How do I get my motor to run the correct direction? The instructions say to reverse the TH if you have a Futaba. I have an M11X. Also it says to switch any motor wires but it is noted for sensorless.
All the connections are correct. I looked over it many times.
What do am I doing wrong? HELP!!!
Thanks~!
Thanks~!
#842
I'm looking to run the motor + esc combo in my HPI Cup Racer as a stock class.
Any suggestions on where I can get it? amain seems to be out of stock. Any other suggestions on a simple motor with that esc?
#843
I have a weird issue of great drag brakes (I can change it using the programming box), but zero brakes with the transmitter trigger. I have reset the speedo and went through the radio set up a couple times. My radio settings are all set up correctly (the problem developed without touching radio settings).
I am using a Spektrum DX3R system with the Citrix.
#844
The factory brake setting is 50%. Using the programming card you can turn up the "ABS" braking to 100% and turn the drag brake down to 0%.
#845
But I have zero throttle braking. If I use the throttle for brakes I then don't get any braking, including drag braking.
#846
Assuming you have the brakes at 100%, when you did the esc setup to your transmitter did you see the yellow led flash three times (page 4 in the instructions) to indicate that the esc was able to set the braking?
#847
The only place I have seen the esc and motor in stock lately is buying directly from speedpassion usa. Even so they don't have the kit but you can get the esc and motor separately.
#848
Terry
#849
I just tried to order from SP in HK yesterday, webpage said limited stock, my order went into RESERVED. They do not have stock, I hate companies that do this. They were kind enough to ship the programing box that is useless to me without the speed control. I would not order from them without confirming that they actually have stock, I did not..... my bad. Learn from my mistake!
Terry
Terry
Also...I have checked the backend and we do have that combo instock from HK, it is saying reserved is probably the accounting is waiting for tomorrow to clear the fund. It will be ship soon enough.
#850
I wasn't that clear. I can adjust drag brakes to any setting I want and they work perfectly. Great braking while using drag brakes, the ESC works perfectly with this function.
#851
I see the USA warehouse has the Cirtix Club Spec ESC and the V3 Ultra Sportsman 21.5 both are instock.....we might not have the combo but you can still buy them separately and the total will still be the same around $100 USD plus shipping.
Terry
#852
#854
#855
Where in the US can I order the combo (or individual motor + esc)? I can't seem to find it in stock from the usual amain.
