Speed Passion Cirtix Stock CLUB ESC
#571
Ok, I know from experience this esc will not work with LRP motors.
Wish I would have known before you put your's in Steve and I would have told you.
We have gotten them to work with Duo 1's and 2's as well as Orion's, Novak's, but only if they have the USVTA sticker on the box.
Oh and since I tried the other motors does that mean I ruined the ESC? Guess I'll find out soon enough
#572
So, now we just try to make sure the customer knows, much like the Havoc series is, with only being "intended" to work with brand specific motors.
#573
Ahh ok. I tried it with the LRP, D3 and the Speed Passion V3 17.5...but the same results with all of them. I'll try my old 17.5R I have and I also have a Nemesis I could try. And the box does have the USVTA sticker on it...
DO NOT try the Nemesis, it WILL let any remaining smoke out.
#574
#576
See you at the races...Ed
#577
So I bought one of these instead of getting my Tekin fixed.
Installed it with an LRP x12 17.5. Reversed the throttle on my DX3R..set EPA to 100%. Calibrated the ESC; neutral - button - one beep, full throttle - button - two beeps, brake - button - three beeps. I then reset the ESC and I get a solid yellow with a flashing red LED and I get no throttle response whatsoever. I've tried this with two other motors...Trinity D3 17.5 and SP V3 17.5. Did I buy a dud???
You have 90 days warranty period...contact Albert @ SP Chicago office and he will get that replaced for you....make sure you have your receipt attached for warranty services...and follow the RMA process. Thanks.
BTW...Jimmy and I ran the club spec with X12 LRP motor the whole summer, along with the Novak SS 21.5, then later the Novak Ballistic 25.5 motor......all working fine.
#581
I finally solved the problem with the Cirtix 17.5 club combo. When I got it there was a problem and the motor would only stutter and not go. Found out the sensor wire was broken off in a few places where it goes into the connector. Replaced that, still stutters a little on startup and has a significantly lower top end than other guys running the same combo and it would also get very hot running the same rollout as everyone else. When I contacted Speed Passion they said they couldn't do anything if the motor smelt any bit burnt (not my fault). So I ordered a used novak 17.5 motor on here, put that in today and it runs perfectly. Thankfully the problem was the motor and not the esc.
#582
For those who race Tamiya Champion Series (TCS)....Speed Passion Cirtix Club Spec is one of the legal ESC for the only brushless class, GT1. And the Speed Passion V2 ultra sportsman 17.5 motor is being consider as one of the legal motor as well (but is under review, not allow yet)....
http://www.tamiyausa.com/articles/ln...rules%20V4.pdf
#583
#584
True... And thanks for giving him your input. There is really no reason for the v2 motor not to be included. It is actually at a disadvantage since you can't change the physical timing. Any other 17.5 motor you carry that would be appropriate to the rules should be suggested to Fred (FMW). Thanks! Btw any tracking on my replacement motor?
V2 motor can adjust timing.....it is the owner choice to do it or not. Also, your club race manager decision. Not recommanded but it can be adjusted.
