belts: cutting every OTHER tooth??? >
Old 05-05-2004, 12:59 AM
  #31
xray racer's Avatar
Trader Rating: 22 (100%+)
hey, okay i gather so far that cutting every second tooth off the front diff pulley will give the most benefit right???
so now then... how do i do it? dremel every second tooth flat?
xray racer is offline
Old 05-05-2004, 01:56 AM
  #32
FlyinGT's Avatar
yeah i've done it recently to the belts of my TA04 R
i did feel a difference ....... i could use my pinky on the hex hub an move the drivetrain .......... i couldn't b 4 !!
felt smoother when racing........ car would glide into corners.... rather than come to a quick stop n lose all my speed !!
FlyinGT is offline
Old 05-05-2004, 03:09 AM
  #33
team_tamiya's Avatar
Yeah I have an R to, how far did you cut into each tooth. Have you done anything else to your drive train.
team_tamiya is offline
Old 05-05-2004, 03:39 AM
  #34
FlyinGT's Avatar
Default Use A nail clipper .......!!
I used a nail clipper ....... to cut the belt .... i cut enough so that its flat an even
when u look at the belt side on ......... u cut it so it looks like the tooth was never there ........ exatly where it would start to rise up an ....like a hill then a flat ... then a hill ....... u should get my point(not very good at explaining things >>>!!
i've only done this so far ......... not touching the pulleys just yet .may b when i get some spare ones to play around with !!
FlyinGT is offline
