Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
X12 Rody...Air Filter won't fit ? >
Old 04-28-2004, 10:12 AM
Default X12 Rody...Air Filter won't fit ?
Hi guys,
I bought an X12 Rody and what was my surprise to see that my thrusty MotorSaver air filter won't fit since the air Intake is too big on the motor.
Is there different size of air filters? I am a little confuse... Any recommendation on a new one? I am use to MotorSaver, wish I could find one that fit.
Frag is offline
Old 04-28-2004, 10:14 AM
rod_b's Avatar
You need the .21 size motor saver for Novarossi based engines
rod_b is offline
Old 04-28-2004, 10:39 AM
Hey and about the carb air intake. I saw that there is a plastic filling inside the air intake (writen 5.4 on it) that you can remove. I presume that if I remove the filling, that leave the air intake wide open for more power.
But what are the ROAR rules for air intake opening?
Frag is offline
Old 05-05-2004, 06:49 AM
kt racing's Avatar
As far as roar goes you have to run a 5.4 restrictor. Also don't remove the restrictor completely. You can buy bigger restrictors. If you pull out completely the motor probably won't run the well.
the air filter RB and Racers edge both make big carb air filters for the 12s you can get them from my hobby shop
www.debbiesrcworld.com
hope that helps
keith
kt racing is offline
