NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE >
Like Tree4Likes
Old 01-31-2014, 06:08 AM
  #11521
avs
avs's Avatar
Originally Posted by Blue Sky
Is there plan to have the XERUN-120A-1S V3.1 ROAR approved? Thanks.
+1
Originally Posted by OVA
yes Ronny
Hobbywing 81020340 81020350 81020360 XERUN-120A V3.1 Software V3.1_121129_beta ESC must use Profile #2, red LED on power button flashes when throttle is at neutral in non-timing mode
81020340 81020350 81020360 are the 2s version in 3 colors. the 1s version is not on the approved list. is this a clerical error or something else?
avs is offline
Old 01-31-2014, 06:46 AM
  #11522
Fredp1's Avatar
Trader Rating: 11 (100%+)
Originally Posted by 314ck5h33p
Cobra, used the Reedy 4.0 motor (TC ON), the fast track;
The track is hot (+ / - 50C) and air temp + / - 35C.
My ESC V3.1 (new)!
FDR 8.6 (One CSO). motor was ok! 80 to 90C, max.
But the ESC stoped, it disarmed by overheat protection.
Setup in race was 0º boost and 0º Turbo, for 5 minutes to finish the race.
I tried using 5 points Boost (start 30k and Finish 60.000) and thus was up to 4 minutes (overheat protection).
I can not use this set?
Motor Reedy first generation with Reedy 6500 65C lipos. Endbell is a Zero points.
Tks.
Cannot comment on your setup, but I wouldn't run a motor over 70c. The temp measured at the end bell can be 3 times or more internally.
I'm not surprised the speedy shut it self down.
You may have been fortunate it did, as it saved a motor from going up in smoke.
Fredp1 is offline
Old 01-31-2014, 08:34 AM
  #11523
aSab's Avatar
Angelo,
congrats for getting Atsushi Hara onto the Hobbywing team! I wish all of you good luck! (everyone can now see, that the hard work like yours really pays off)
aSab is offline
Old 01-31-2014, 11:08 AM
  #11524
COBRARACING's Avatar
Originally Posted by aSab
Angelo,
Thank you for the kind words i really appreciate it .I try my best thats all i can do i am the face of Hw and i need to work harder to keep HW at the top not only in quality design and performance but more important than all of that is the the tech support and after sales service.
I dont believe that a customer needs to wait 2 weeks for a reply i believe 24hours max .
We need to work harder because other esc manufacturers or brands will start catching up and i will not allow that to happen i must be atleast 2-3 years ahead in all levels.
Once again thank you for your kind words
Angelo
COBRARACING is offline
Old 01-31-2014, 11:10 AM
  #11525
Originally Posted by avs
+1
Im sure its a typo as i know it has been approved because i know the software is approved for all v3 and 2.1 series esc's ill check with roar next monday-tuesday.
Old 01-31-2014, 11:13 AM
  #11526
My ESC V3.1 (new)!
Tks.
Send me an email at [email protected]
Old 01-31-2014, 12:08 PM
  #11527
Tks Cobra... sent my setup sheet.
314ck5h33p is offline
Old 02-02-2014, 09:52 AM
  #11528
AlanHall's Avatar
Trader Rating: 43 (100%+)
running 17.5 blinky will i see any differentce in running a just stock vs stock spec 3.1 or the competition v3.1? also i say on the hw website the lcd box had stopped production? is there somthing new ?
AlanHall is offline
Old 02-02-2014, 01:10 PM
  #11529
All 3 are top escs the justock is zero timing and no other software can be loaded it is also part of the v2 family of esc like the 120 amp ,60 amp and xtreme stock which csn run boost timing and turbo etc.
The other escs you mentioned are part of the new generation v3 and can run zero timing but also boost and turbo timing applications.
If you are running on blinky and always running blinky stick with the justock which can run down to a 8.5t motor if turbo is needed and lower turn motors the others mentioned will work fine with zero and turbo .The v3 also runs different software with more adjustability and options and is fitted with a cnc aluminium case for better heat dissipation.v3.1 120 amp competition only.
There is a new lcd program box which can run both version and also has a built in lipo voltage checker.
Send me an email if you want to know more or need a setup to begin with i will be vety happy to help you out. [email protected]
Old 02-02-2014, 01:34 PM
  #11530
AlanHall's Avatar
thanks for the reply. i wasnt sure if the 3.1 software made more power or smoothness difference or somthing i wasnt seeing . the esc will be in touring car 17.5 blinky 95% of the time. possibly with an option to run in 2wd off road.
AlanHall is offline
Old 02-02-2014, 07:14 PM
  #11531
The v3 series esc's are the worlds most powerful and smoothest .The software is also the most advanced.
Old 02-02-2014, 07:56 PM
  #11532
Trader Rating: 27 (100%+)
There's a slight difference in feel between the v2.1 and the v3 firmwares.
That being said, it's a very small difference in feel on the carpet. I've used pretty much every HW ESC, from the Justock to the 60a, 90a, 120a, 120v3, 120v3.1, Stock Spec v3.1.
ANY of them are awesome in blinky. For mod, I greatly prefer the v3 firmware though.
hyujmn is offline
Old 02-02-2014, 07:58 PM
  #11533
evochick's Avatar
One of the features i like on the V3's which is really handy for blinky mode touring car is the fan port.
You dont need to run the ESC fan for 17.5 and 13.5 it just doesnt get hot enough, so you can use the fan port to plug your motor fan in. This port is also high voltage so you can run 8.4 volt fans with no issues.
Beth. (happy hobbywing customer)
evochick is offline
Old 02-03-2014, 02:31 PM
  #11534
AlanHall's Avatar
thanks for the replys. I think ill go with the stock spec 3.1 over the just stock then.
AlanHall is offline
Old 02-03-2014, 03:28 PM
  #11535
The stock spec is awesome. I run one on my blinky car. Awesome ESC.
hyujmn is offline
