Clutch Bearings >
Clutch Bearings
Like Tree14Likes
Clutch Bearings
Old 04-25-2010, 03:22 PM
hdcruzer's Avatar
Trader Rating: 12 (100%+)
Default Clutch Bearings
What clutch bearings are you guys running? Ive been running avids and keep blowing them out at about a half gallon. Need some other options........
hdcruzer is offline
Old 04-25-2010, 03:30 PM
losi_racer's Avatar
Trader Rating: 25 (100%+)
avid bearings cant handle the heat, i use them for wheel bearings and they are awesome, the avids for clutch were not. ive been using tko ceramic bearings, they last forever and they have extended the life of my clutch
losi_racer is offline
Old 04-25-2010, 03:32 PM
Kalgard Racing's Avatar
Ready Rollers, atleast 2 gallons per set. The best I have found so far!
Kalgard Racing is offline
Old 04-25-2010, 03:38 PM
Shoaf85's Avatar
Trader Rating: 19 (100%+)
answer-rc here!
Shoaf85 is offline
Old 04-25-2010, 03:41 PM
cordarrow's Avatar
Trader Rating: 17 (100%+)
Now that's funny.........
I change them after every race...
As does anyone that's anybody.....
cordarrow is offline
Old 04-25-2010, 03:43 PM
wallot's Avatar
avid, answer-rc, abec-35, TKO, . I check my clutch after qualifiers and then after any longer main and replace them if needed.
wallot is offline
Old 04-25-2010, 03:46 PM
cordarrow's Avatar
Which reminds me....I need to find a filter oil that will go two gallons...
I'm having to change filters after one gallon....LOL
kruzracing169 likes this.
Peter Martin's Avatar
The TKO special bearings are not ceramic....just a special design. If you would like to try a set please email [email protected].
http://tkocompetitiondev.com/product...roducts_id=341
Peter Martin is offline
Old 04-25-2010, 03:54 PM
hdcruzer's Avatar
I just bought some answer bearings. Little more expensive then avid so hopefully a little bit better. The avids that I was running were not even lasting a half gallon.
hdcruzer is offline
Old 04-25-2010, 04:04 PM
Tech Prophet
tc5 man's Avatar
thats if you buy the dollar clutch bearings , get some tko bearings no need to change them. intill after a gallon, or so say smooth for a long time.
tc5 man is offline
Old 04-25-2010, 04:33 PM
dadsvtechonda's Avatar
ready rollers have never had a problem at all run them in my whole truck and motors
dadsvtechonda is offline
Old 04-25-2010, 04:44 PM
mudboger07's Avatar
I use the dollar bearing, I run one set for the qual then change to new ones for the main, I dont want to chance ruining any gears, fuel tank and clutch trying to get more out of a set of bearing....
mudboger07 is offline
Old 04-25-2010, 04:45 PM
JAMMINKRAZY's Avatar
I use $1 protek metal shielded bearings. I use an RPM bearing blaster and nitro spray to blast the grease out, and oil them with Racers Edge modified bearing oil. They will last around a gallon or so if you want them to. I just change them every club weekend, or before a long main at a big race.
I have been meaning to give the TKO's a shot but their always on backorder when I make my Amain orders.
JAMMINKRAZY is offline
Old 04-25-2010, 05:46 PM
Tech Prophet
tc5 man's Avatar
carolina r/c has some tko clutch bearings in stock.
when you blow the grease out of the clutch bearings, do you leave one side without the shield, or do you put the seal back on?
tc5 man is offline
Old 04-25-2010, 05:47 PM
Tech Prophet
tc5 man's Avatar
trust me man if you get a set of, tko bearings you wont have to worry about that problem.
tc5 man is offline
