68 mph micro
Old 07-07-2004, 03:22 PM
  #211
ajg
Registered User
ajg's Avatar
New pics: http://www.one18th.com/showtoy.php?id=2799
ajg is offline
Old 07-09-2004, 10:41 AM
  #212
ajg
Registered User
ajg's Avatar
Originally posted by ajg
Do any of you guys have ideas for were I should put the magnet for the sensor? I think I might put it on the rear diff or spur gear.
Anyone?
ajg is offline
Old 07-10-2004, 07:41 PM
  #213
ajg
Registered User
ajg's Avatar
75 mph
Sorry about pic, it was at night and the flash was making it too bright, so I had to try to cover the flash. The speed is the best run I had.
ajg is offline
Old 07-11-2004, 11:12 AM
  #214
ajg
Registered User
ajg's Avatar
I got 82 mph with a freshly charged battery pack. Also, on the speed meter, it says that the battery voltage is 5.6 volts, shouldn't it be 7.2? Please explain. Maybe some of my cells are bad.
I'll post new pics of the car with the speed meter.
ajg is offline
Old 07-11-2004, 11:17 AM
  #215
kufman's Avatar
Was that voltage under load? A fully charged 6 cell should be up around 8V without a load.
kufman is offline
Old 07-11-2004, 11:27 AM
  #216
ajg
Registered User
ajg's Avatar
That's what I was thinking, since it's 1.4 volts per cell when charging, It was just sitting there when I looked at it, it was the same with a fully charged and almost drained battery pack.
ajg is offline
Old 07-11-2004, 11:56 AM
  #217
ajg
Registered User
ajg's Avatar
New pics: http://www.one18th.com/showtoy.php?id=2811
ajg is offline
Old 07-12-2004, 09:29 AM
  #218
ajg
Registered User
ajg's Avatar
Is there a way of testing the cells/battery pack to see if they're all good?
ajg is offline
Old 07-12-2004, 09:36 AM
  #219
ajg
Registered User
ajg's Avatar
Seeing if my sig got smaller, didn't work. Got it working, it's smaller, and a different color.
ajg is offline
Old 07-12-2004, 09:42 AM
  #220
kufman's Avatar
The only real way to test for weak or dead cells is to use a load test. draw a constant current from the pack and measure each cell's voltage indiviually and see if there are any with much lower voltage than the rest. a really dead cell will have very little voltage or no voltage when there isn't a load.
kufman is offline
Old 07-12-2004, 09:44 AM
  #221
ajg
Registered User
ajg's Avatar
What do I use to test them? Should I test them on the car?
ajg is offline
Old 07-12-2004, 10:29 AM
  #222
kufman's Avatar
That is the hard part, what to use as a load. 1157 tail light bulbs make a descent discharger. 10 of them in parallel is roughly 20 amps. 5 in parallel would be about 10 amps ...... etc. Do you have a charger with a discharge? If so you could use that even if it is only a couple of amps. I am not sure on the current rating of the cells you use. For normal sub-c's I would use 20 amps as a good test.
kufman is offline
Old 07-12-2004, 11:29 AM
  #223
ajg
Registered User
ajg's Avatar
Ok, thanks.
ajg is offline
Old 07-12-2004, 01:41 PM
  #224
intimidator's Avatar
you should enter your car in that all out speed competition in califonia that r.c.c.a. is having.
intimidator is offline
Old 07-12-2004, 02:16 PM
  #225
GundamWZero's Avatar
I copied this from your site:
viciousracer wrote on Jul 11, 2004 - 5:06 pm
just a coment fromn a factory team driver from Venom,... you are way off bro,....your cells wont allow you to go 80+ mph. only lio poly will, with a brushless for that matter....plus you have the magnet rotatin on the axel. needs to be placed on the drive spool/diff. your getting a fauls reading due to the tire spin,...even when you think you have FULL traction you DONT!!!! recalibrate and move the magnets,... Harley Team Vicious Tekin Racing,Venom Racing, RD Logics, Castel Creations, Team Paridiugm, Speedworld Raceway, Kimbrough,Fusion Cells, Team Apogee.
ajg wrote on Jul 11, 2004 - 2:03 pm
Continued: You enter it in the speed meter when setting it up. The magnet makes as many rotations as the wheels
ajg wrote on Jul 11, 2004 - 2:01 pm
Yes, you enter in the lengths of when the magnet does one full rotation, and the magnet is conected to the drive shaft.
Did want to get all of it, but can you explain to us all how come you car can post 80+ and other micros of the same group can't achieve this speed without going lithium ion on the batteries and using brushless motors.
just curious...........
GundamWZero is offline
