Tamiya FF03
#2491
I ran one a little while ago and was running 84t spur and something around 48-53t pinion. You haven't given us a lot of information really, what size track is it? Fast and Technical?
#2492
Any news on those transmision halves ( the FF03R ones) ?
#2493
Nothing yet
Been keeping a close eye on Tamiya's site and nothing......
Don't think they will be out too soon though as they will want to sell a few hundred R kits first
#2494
#2495
Spool now available for the FF03R!
It's actually a rear spool from the TA06 but as the geardiff for the FF03R is a rear TA06 geardiff, it is a direct replacement!
NOTE that this spool is only specified for the FF03R so would require the new gear casing to fit into the FF03 and FF03pro models
#2496
FINALLY!!!!!
54398 - Tamiya Gear Case for Gear Differential FF03
You won't find any in stock anywhere and there are only a handful of online shops that have it advertised!!
Should take another month....or two
#2498
Have many people run the Spec-R gear diff in the FF03? How does it hold up?
#2499
My FF03
FF03- I love it, Here are some pictures of my FF03
https://picasaweb.google.com/lh/phot...eat=directlink
#2500
Pristine FF03 Pro
In case someone is looking for an FF03 Pro with special sauce
http://www.rctech.net/forum/r-c-item...l#post10941007
#2501
Hey everyone! Picked this up during my travels in Shanghai, China!
Futaba ESC
Futaba 2.4 Radio
Futaba BL Metal Servo
Tamiya Super Stock RZ
2S 40C 5300mah Lipo
This thing is quick!
Has anyone experienced a warped diff joint? The right diff joint seems warped and is rattling the dogbone around. I've ordered aluminum diff joints to hopefully solve the problem.
Futaba ESC
Futaba 2.4 Radio
2S 40C 5300mah Lipo
#2502
#2503
Wow hectic gearing....and that looks like 48P too
#2504
Anybody know a good spur/pinion combination for the silver can on asphalt for TCS? Thanks
#2505
Will 44mm cvd's made for the tb03 or ta05 work for our ff03 with aluminum diff joints?
