can som1 help me with rb ws7 lll
hi i brought a rb ws7 lll second hand not uesd alot but having trouble setting it up . ive ajusted mixture out 7 turns witch 2 me seems alot . the car runs well at this but theres still no trail of smoke only at low speed
If those settings are too lean then there is an air leak or something.
What pipe setup are you using on the engine?
im using jammin p1
You may also want to back-flush your fuel filter. Check for bubbles in the fuel line. Check for good fuel flow by disconnecting both lines from the engine and pipe, blow into the pressure line and observe the fuel flowing out of the other tube. It's also possable there is some crud inside the carb partially blocking fuel flow.
Is the fuel inlet on the carb loose or leaking?
If everything checks out, then I would suspect a leak on the block, carb backplate, bearing...
thanks il check all that un see how it goes
