Hot Bodies TCX
Old 10-11-2010, 05:23 PM
  #1066
ark
Trader Rating: 11 (100%+)
Nice to see some more setup sheets soon
ark is offline
Old 10-11-2010, 05:30 PM
  #1067
Luke Hobson's Avatar
my blog in the sig below has been updated with the set up that i ran during the weekend, 99% is the same as ive been running everywhere on carpet, mainly just playing with additive times to find the right balance of the car for the whole run.
hth
luke
Luke Hobson is offline
Old 10-11-2010, 05:33 PM
  #1068
So at 490-415$
Is this car the middle of the road, or higher end of cost?
Was this a raised price compared to the cyclone??
Looking at this one and the Associated T6....
what was the T5 like??
Thanks.
Hermit 713 is offline
Old 10-11-2010, 05:39 PM
  #1069
Is it me, or does the Xray T3 look like the TCX, or the TCX look like the Xray
T3??
It has a upper deck the same as the TX3...?? You can adjust the flex the same way???
Old 10-11-2010, 08:20 PM
  #1070
STLNLST's Avatar
Trader Rating: 32 (100%+)
Originally Posted by gdcopbdcop
yesterday at the castle classic at nor-cal, i broke both of the front dogbones on my tcx. a buddy gave me 2 complete dogbones/axles to try from his T.O.P. car. i used my dremel to narrow the plastic blades a bit, but it was a perfect fit,,,,46mm, and the best part, they are steel dogbones.
Broke both of them.....geeeezzz bro. On the old car steel Tamiya bones worked out. I'd check and see about those if you run into problems with the Top one's.
STLNLST is offline
Old 10-11-2010, 08:26 PM
  #1071
hey, you know me, i can break anything..lol....the dogbones are 46mm long, the tamiya ones are only 44mm,,,the TOP dogbones worked great, but i did have to dremel down the blades to make it fit,,,lucky there is a lot of material on the blades
gdcopbdcop is offline
Old 10-11-2010, 08:39 PM
  #1072
STLNLST's Avatar
Tamiya offers a 46mm bone too I believe.
STLNLST is offline
Old 10-11-2010, 09:05 PM
  #1073
i will check it out,,,,but the ends of the bones on the new tcx are way fatter, ,,,call me, i have that body and car for you...
Old 10-11-2010, 09:39 PM
  #1074
Suspended
Trader Rating: 86 (100%+)
yesterday i had a chance to try my NEW tcx in my club race, it was 17.5 WITHOUT boost and the dog bones are starting to showing signs of wear.
which dog bones that will last longer and fit tcx?
littlealex is offline
Old 10-11-2010, 09:45 PM
  #1075
STLNLST's Avatar
I will call you tomorrow since it's late. Thanks again for picking them up.
STLNLST is offline
Old 10-12-2010, 12:20 AM
  #1076
Airwave's Avatar
I had a dogbone "redesigned" too last last week-end...
I obviously try the Tamiya but the kingpin are too small to fit the spool...
I've ordered some Sakura parts to adapt the gear diff... Maybe it could be a perfect replacement for our dogbones... And if it does not fit, maybe I can try to adapt the outdrives or the totality of the Sakura spool...
Airwave is offline
Old 10-12-2010, 01:21 AM
  #1077
Suspended
why would tcx make their aluminum axles so weak and not offering stronger option front axles for tcx?? does every tcx owner have to modify other manufacturers axles?
Old 10-12-2010, 03:08 AM
  #1078
Where are your bones wearing? Can you post a picture up?
With 17.5 zero boost you shouldn't have ANY wear problems pretty much ever.
I've been running mod and 10.5 (with boost) for about 40 runs so far with no wear or broken bones....
What type of grease and anti wear grease are you using?
Old 10-12-2010, 03:13 AM
  #1079
Barry_Hughes's Avatar
The bones wear on the slot where the UJ pin goes through. I have gone through one already, the original other one is showing lots of wear.
I am running 13.5T
Hopefully steel 46mm bones will be available soon, at £9 each for the alu ones it is expensive!
I am think of trying the TC 44mm steel versions - as long as they don't pop out
Barry_Hughes is offline
Old 10-12-2010, 05:07 AM
  #1080
san.'s Avatar
Trader Rating: 61 (100%+)
Yes, stock 46mm shafts are showing extreme wear. After two weeks of running at Horsham, the axle end of the shaft is already egg'ed out. I run 17.5T Open.
Does anyone know if the Sakura 46mm shaft a direct fit?
san. is offline
