Hot Bodies TCX
#3076
#3077
thinner hexes
Why do alot of racers use the thinner hexes with a 0.5mm shim. I measured the hexes and they're just over 4.3mm so if you add a 0.5mm shim your pretty much taking it back to the std hex size, any views?
#3078
If i remember correctly, thinner (4mm) hex is actually about 4.2mm like your measurement and the stock one (5mm) should be about 4.9mm. So there still is 0.2mm difference between the thinner one w/ a 0.5mm spacer and the stock one.
When you want more roll on the car, using 4mm hexes all around would be good.
#3079
Its a photon spool with sidepiece outdrives. Xray c hubs and knuckles. I have the 3racing sakura s 4mm hubs on currently, cost about 1/3 of the hb set i bought, and much easier to get a hold of.
#3080
thanks mike, is xray chub direct fit? i have a friend want to use hb cvd that will need bigger chub.
#3081
Its a 3mm hinge pin, you will need to drill the arm bigger and get a 3mm pin. Also will need th ebushings to match the c hub
#3082
They will have to cut their postage costs to UK/Ireland if they us guys to use their products! I tried to but a TCX chassis and got quoted $32 for postage at checkout. Dont think so.........
#3083
with all things being equal - is there any advantage to running a bigger spur over a smaller spur if you can make the same FDR?
i know some times a smaller spur will give you a bigger range of adjustments - but is there an advantage to running the one over the other aside from this?
this is just something i've been pondering for a little while
#3084
1) Changing the spur sizes is a handy tool for changing the balance of the car. It can let you move the motor forwards and backwards in a belt car or for a shaftie, in and out of the centre line
2) Don't go too extreme because the gear mesh gets tricky and less efficient if there is a large spur and small pinion
#3085
Has anyone tried the TCX specific Spec-R gear diff (SPR009-HB)?
I had a question about the out drives. Are the HB bones a direct fit or do we still need to do dremel work and use plastic blades?
#3087
What other brand blades can be used? The HB ones are hard to find and very expensive.
#3090
Hello,
In the last weeks i read more in this thread. I had Change from TRF417 to the TCX. I hope it was a good change :-)
I've changed the following:
Spec-R gear Diff with MR33 Type A Diff. Oil
Tamiya 46mm Steel Drive Shaft
Spec-R Shock Tower -2
Roche Spool
Geiger Chassis
4mm Hex with 0,2mm Spec-R Diff Shim in Front
Yokomo Steering Knuckle
Next Race is ETS in Andernach
Roche Spool
Geiger Chassis
