Hot Bodies TCX
#2597
Well, on mine atleast the cross piece that the two little bearings sit into that attaches to the two cranks has opened up, which creates alot of play for me. The only trick to curing it is to dap a bit of super glue inside where the bearings sit, so they fit snugly, but soon enough the play is back. Im pretty sure this is why most of the other cars out there have changed the design so that the cross part attatches on top of the cranks rather than below.
#2598
The steering issue may be an isolated problem. I have zero slop or binding. It has worked flawless and freely.
If at any point the steering rack came loose and was operated that way the end result would be abnormal wear and tear.
I had a post loosen but I found nothing wrong with it. The top brace kept it in place and the screw that backed out showed no carpet burns.
Just replace the worn part and be done with it.
#2599
Could somebody tell me where could i find others drivers setup sheets, please?
Could someone recommend well which basic setup should i run on smooth, high traction and large asphalt track, please?
Best regards
Best regards
#2600
#2601
If at any point the steering rack came loose and was operated that way the end result wound be abnormal wear and tear.
The steering rack is £60 over here! HB don't sell the parts seperatly.
#2602
#2604
#2608
#2609
Anyway, could anybody tell me if i have to buy Tamiya 44mm swing shaft if use 3racing gear diff in rear?
I just has got 46mm.
In fact HPI shaft doesn't fit.
Best regards
