Mugen MBX5 Shocks >
Mugen MBX5 Shocks
Mugen MBX5 Shocks
Old 03-31-2010, 09:01 PM
rast4man's Avatar
Trader Rating: 27 (94%+)
Default Mugen MBX5 Shocks
What are some options, perhaps from other buggies, for big bore threaded shock upgrades for the Mugen? I checked my 8ight and D8 and the fronts will work but the rears on the Mugen are very long. It looks like some Ofna shocks might work since they are similar in length for the rears and I checked eBay and there is a pair for $65 that are purple but they look pretty generic.
So, what are you guys running for shock upgrades on your MBX5R's?
Thanks,
Rob
rast4man is offline
Old 04-01-2010, 03:48 AM
hi the shocks from the mbx6 are the same length. they even use the same seal kit and shaft's
rustyrevo is offline
Old 04-01-2010, 04:36 PM
rast4man's Avatar
But are they threaded?
rast4man is offline
Old 04-01-2010, 05:38 PM
moeman's Avatar
Trader Rating: 26 (100%+)
I use Jammin 16mm big bores. They are sweet! You have to use the jammin mounts too.
moeman is offline
Old 04-01-2010, 07:39 PM
Davidka's Avatar
Trader Rating: 86 (100%+)
MBX5r's run best with the stock shocks. Changing to big bores is a sure-fire way to get lost in setup land. I have never driven a more stable buggy than a 5r (including my MBX6).
Davidka is offline
Old 04-01-2010, 09:08 PM
rast4man's Avatar
I've heard that the stock setup is best. I guess I'll just play with the shock oils and maybe rebuild the inners, if possible and see how it goes.
rast4man is offline
Old 04-02-2010, 09:46 AM
Davidka's Avatar
Start with 27.5 Rear/32.5 front oil and the gray springs. Mount shocks in the middle on the tower, outside on the arms. That was the most common combination for the 5R and works everywhere.
Davidka is offline
Old 04-02-2010, 12:12 PM
awdcameolsx's Avatar
Trader Rating: 36 (100%+)
Last season I tried mbx6 shocks on my mbx5r. Worst thing I ever did to that car EVER. Like stated above, I was caught very lost in setup land. The stockers are nice and smooth, and the spacers are nice because they are consistent.
awdcameolsx is offline
