Gear ratio/roll out chart...how to calculate?
Hi guys,
I am looking at the setup sheet of my Evolva. Inside there are some gear ratio charts and roll out chart. I don't have a clue as to how these values comes. Can someone supply a formula?
hey
it depends on what type of track u run on tight technical track u need accel out of corners fast so u need to run tall spur gears with small pinion gears.with a 3tooth split.i run a g4 eclass.this is how my gear ratio works. for a short i run 20/52 1st gear 2nd gear 24/48 my eng is a rody rbx12. with gear set my car accel like a rocket .now for a big track which is where they run 1/8 scale onroad i run 20/51 1st gear 2nd 24/47. i hope this can at least point u in the right direction . like i said big on spur small on pinion for short tracks.
too work out your overall gear ratio you first need to know the cars internal gear ratio, this should be in the manual somewhere, touring cars are usually aroung 2-2.5/1
for example first gear 20/52 2nd 24/48 internal ratio 2.2/1
first gear would be 52 divided by 20 multipied by 2.2=5.72
2nd would be 48 / 24 x 2.2 =4.4
the lower the number the faster the car will go
know you say a rollout chart, in the uk we measure this mm per rev, if this is the same thing this worked out as follows
size of the rear tyre divided by overall gear ratio multipied by pie
first gear with 65mm tyre
65 / 5.72 x 3.142 =35.7mm per rev
2nd
65 / 4.4 x 3.142=46.4mm per rev
mm per rev basically 1 revolution of the engine the car will travel 35.7mm in first gear and 46.4 in 2nd
hope this make sense
2nd
Dear jas1,
Thanks a bunch for your very informative replies!
One more....How about the calculation of the Front/Rear Overdrive Ratio Table?
try this link
http://www.rolfje.com/
then click r/c calculator kit
then click the ratio computer
then fill in all boxes and it should work the overdrive ratio for you.
dont know if it works or not
