How long to charge lipo
How many amps are you charging? At that mah u should be a 2. I have a common sense rx pack that I can charge at 3 or 4 c and only need to top it off once a day.
question is why are you charging it after Every quali...are you not noticing its only taking 100-200 mah ?
Wow you charge that often???? i do it mid day just to keep track. i could probably do a entire club race with out charging.
You do not have to charge a lipo that often. That is one of the advantages of running lipo. You can fully charge it and it can last two race weekends easily with no charge. A 1600 nimh will last for 3 quals and a main as well. You are definetly over charging the battery. Hope this helps.
2 weekends....that depends on A Lot of factors.
To answer your question.... you don't have to worry about shutting it off ... hyporion charger you mentioned will stop charging once it senses that the battery is fully charged. And you should always charge it completely when you charge. As far as the actual charging time, it will depend on how drained the battery was.
I think he's asking how long should he charge the battery for, not how often...
