Tamiya TB-Evolution IV
#1396
Re: Re: Drive cups
Originally posted by EVOtech
or wait for Square metal ones.
#1398
There will be a lot of hopup parts available in the coming months. As to what they are and when they will be released, I don't know exactly because I wasn't paying attention hehe woops. But I did hear input cups, aluminum hub carriers, umm yeah I wasn't paying attention...I might have been busy looking at eye candy at the time
#1399
The Evicerator
So Rod you given up on running at socal?
#1400
Steve, I miss running at socal but I've been busy with projects and when I get off of work, I've been very lazy as of late. I believe that I should be able to start coming back for Tuesday night national championships very soon but will probably run stock (less stress ).
#1401
The Evicerator
I think you know the tamiya layout well enough that you could stand to miss a saturday of tamiya fest for racing at socal... if you really wanted to that is
#1403
#1404
If any of you want a NIB EVO4, I can get you one for about $359 shipped depending on where you live.
PM me if your interested.
#1406
#1408
drive cups
Originally posted by KilRuf
I have a quick solution for you guys with main shaft cup problems. I was at the Norrca Nats this weekend at TFB Raceway. I didn't race my Evo IV. But I ran it a few times and ended up breaking one of my main shaft cups. Fernando didn't have any spares. But Eric Anderson did and gave one to me (Thanks Eric!! ). Anyways, that night I can up with an idea to use the spare diff joint rings that came in the kit. Just slip them over the drive cups. They fit nice and tight. You can even add a drop of superglue to them. But if you do, your main shaft main be alittle hard to take out of the cups. Here is a pic....
vic
#1409
I have run my car with the outdrive/diff rings over the cups since uhh I broke my first and only drive up. And it's still holding up with no problems. I did superglue the ring on the rear drive cup... but I didn't do the front one. I don't think you really need to glue them. Just press them on after you have the shaft inside the cups. This'll make life easier if you want to remove the shaft. And yes... it is sorta hard to put into the drive up with the ring on. I'm gonna wait for the new cups to come out and try those though... but til then.. this mod works for me with no worries. Oh and as for the rotation... I'm not to worried because it's not like an outdrive where the shaft will move up and down, forward or backwards like suspension shafts. The main shaft is stationary (except rotation and slight chassis flex) and just transfers power from the rear gear box to the front gear box.
#1410
Re: Re: Re: Drive cups
Originally posted by rtypec
...or wait for Tamiya goodies
