Tamiya TB-Evolution IV
#2851
Look at my previous posts and you will see my foam carpet setup. The car is plenty strong and if they are stipping bevels, they are shimming or setting the backlash wrong. I stripped one crown gear because I forgot to Loctite the screw. Other than that, I am on the same gears and I run 8x1 and sometimes with a spool. If that isn't hard on the drivetrain, I don't know what is.
I also wrote an explanation of how to shim properly. Just search the previous posts in this thread.
#2853
Hello
Somebody can tell me where i can find a spool with delrin output please. Because Speedtech have one (metal output) but it do a lot of noise.
Thank you
Stefan
Thank you
Stefan
#2856
Or get the white diff... take the diff balls out. Take out the bearings and replace them with bushings. Superglue the bushings and diff rings into place. Super glue the diff gear down to an outdrive. Take out the thrust bearing and spring. Replace them with about 6mm worth of 5.5 shims. Tighten it down all the way. Then superglue the oudrives to the diff gear. There's your spool. Of course F. Alonso's way is easier.. hehe. But this was how it was explained in RC World December 2004 issue by TRF guys. Except they used the normal black outdrives...
#2857
Originally posted by clint
what is the easiest wat to fit 28mm foam tires on the front of my evo iv?
Seriously, you don't need the extra tire material up front. The Evo4 has never been at a loss for steering. I usually have to dial out a bunch of steering on my car.
#2858
Need some help
Hello
somebody can tell me where i can find some setup for TB evo 4 in outdoor ?
Thank you very much
Syéfan
Thank you very much
Syéfan
#2860
Originally posted by Csaari77
I just got my evo 4 ms put together. The first race for the car will be this Sat. I was wondering if anyone has any set-up info for it? I realize that it's a new kit, but there isn't really any setup help in the instructions.
-Dave
#2861
Does the MS come with the same box setup as the regular Evo 4?
#2863
So what is the Ms's box setup.
Can you post it, or the differences please?
#2865
Im buying a friends Evo IV off him, he has that and the 415ms and hes sticking with the 415 for racing modified, i just racing stock 99% of the time, so im going for the evo 4 with a ton of spares. Hes said that the front spool or one way has stripped a few times, im guessing its either because he has it shimmed slightly wrong or just because running modified is so hard on the car. Ill read back a few pages for that shimming guide.
Will tamiya do an upgrade kit to make the standard evo 4 into the MS?
The blue centre Y piece looks like a good improvement over the standard plastic horrible thing. Im guessing it reduces chassis flex?
