Team PRP racing components
#121
Originally posted by True R/C Racing
Question.... What Does the "Tru Spin" Actually do? From what im thinking It takes the flex out of the spur gear?
next time I order...will get more for my other cars...
#122
Trader Rating: 32 (100%+)
Yeah it will help your spur gear spin true and lessen the chance of Flexing the gear and wobble in the gear.
That's great news Ben....the HTS chassis has been a solid chassis from the get go and so far on every surface it has excelled. To all the Pro-4 owners out there this is the chassis to get if you are looking aftermarket.......its made a great car even better just by installing it. And with everything in the kit for that price its a great deal!!!!
#123
That sounds awesome for the price. What are the advantages, except that its 3mm, of the chassis over the stock one.
Cheers,
Mossie
Cheers,
Mossie
#125
Mossie....There are a few nice features of the HTS chassis....and so far in testing its worked great on carpet to parking lot tracks. Some of the features are that you can use 3 center post to stiffen up the chassis or move them around to get a desired flex in the car....IE one post in the front and the rear of the chassis has more flex.....one in the rear the front has more flex....its a tuning option.....that has a great effect on the car. There is another set of holes in the rear of the car so you can move the rear roll center block further back so you can make an even greater wheel base adjustment then you can in stock form....this has been a great adjustment and Im sure everyone will see the benefits to this once they get the chassis. The Chassis is VERY ridged so it will be more responsive. Also there are locating holes for some Alum. Trans cases that are in the works and they will key everything in place. There is a guard system that will help protect your electronics in a side impact....which is a very nice touch. All in all this is a great chassis to add to your Pro-4 and you will see the benefits once you have the chassis.
#127
Thanks for replying to Mossie, Kevin. I think you covered everything
Not only do you get the added tuning features which Kevin covered very well, but it actually looks different than the stock chassis and upper deck. It has it's own unique style. The upper deck is also a bit wider than the stock upper deck- it's ultra rigid!
#128
XXXS MTII
Thanks, jkerr! I'll try to get more info posted by the 14th.
#129
Ben,
I ran the car this weekend on an outdoor asphalt track with rubber tires in modified and this chassis is still great. You can still feel all the adjustments that you make to the car even on rubber tires outside. That showed me that this chassis is great to have even if you race on rubber tires outside as well. If you are racing a Pro-4 on rubber tires out side dont be put off by the stiffness of the 3mm HTS chassis....its still performs very well.
#131
Registered User
Here Team PRP.
#132
Pro 4 chassis with side guards/braces
Here is a picture with the side braces in place-
#133
complete kit
We'll being taking pre orders tonight! I'll post again as soon as it's set up.
#135
Thanks, Dave. No timing yet. But I'll keep you guys posted!
