Team PRP racing components
Hi Veecee, with a 3mm chassis you are essentially only changing the height of the inner hinge pin and camber link equally by 0.5mm. They are being raised equally, which does not change the length of your links or the relationship between the links. Therefore, we believe the change of roll center will be very very minute. It would also add more to the cost of the part since this would be a secondary machining process and may result in more rejected parts which I simply can not afford. And last, the area would need be milled out all around the front and back of the car which would reduce strength and decrease the amount of rigidty that a 3mm chassis brings to the car. Therefore I decided against it at this time. Maybe I can look into this process more with future projects.
Hey Rob! Pics should be ready Wednesday night, I hope!
Protc3, thank you!
Protc3, thank you!
Ben, YGM. Glad to see your thread on here.
The gear brace is definately looking good. I still haven't had any gear problems with the gears since running it. It's definately a must-have for the pro4 if you run the one-way, imho.
Very cool. Thanks for the info!
Originally posted by TeamPRP
Hey Clint! I'm working on coming out with something new for the losi towers. Looking to have some news about those before the end of May.
NEW pics!
links to more pictures:
chassis picture 2
chassis picture 3
Here are pics of a few other pieces:
pivot block spacers and steering knuckle plates
2mm countersunk spur plate
#20
One word "SWEEEEEEEEEEEET"
I like the offset antenna mount on the upper plate as to interfere with the chassis stiffener holes.
Steel spool?
Steel spool?
#21
Trader Rating: 32 (100%+)
Looking good there Ben..... Keep it up and I cant wait to get some of that stuff.
#22
VERY nice work!
Good luck,
Kevin
Good luck,
Kevin
#26
Here's that build-up pic
#28
Man that thing looks even better built up. I cant wait to get one of these bad boys.
#29
Thanks again for the comments! Very cool to hear you guys like it.
Also, I know this is the on road forum but we are now accepting pre orders on our RC10T4 carbon fiber battery strap. Some of you guys race off road too, right? If you are interested in the T4 strap please go here: http://www.teamprpracing.com/t4.html
Thanks again!
Ben
Thanks again!
Ben
#30
supersteve, shock towers are on drawing board
