Ask Aaron Waldron
#1816
Have you raced your ad2?
#1817
Tech Prophet
Not yet. It has been raining a ton and I have had family obligations this weekend. I hope to soon. I need to take out the washers in the rear hubs or put longer screws in there before I run it. I have heard a few stories about the kit setup so far and do not want to risk it. Longer screws or no washers should solve that issue.
Aaron-- Have you noticed that the right rear arm hits the spur at full shock compression? I had to file some of the arm away. I know this should not be a real big issue but I do not want the spur to get chewed up on those hard landings.
#1818
It comes with red directionals because that is what we run basically everywhere.
Casper - I haven't seen that yet, but I haven't put my production kit together either.
#1819
Hi Aaron-I am running red Taper Pins on my truck and since I went from stock to mod I have been wearing them out awfully fast.They start going away when as soon as the pins loose their sharp edges.We race on hard packed black dirt-no clay.Is there a basic rule or formula you use to determine what compound to use after you find the right tire? The chart on the Losi site is a little vague.I know it comes down to going to my track and trying them all out but tire testing can be expensive! Thanks.
#1820
More power is going to wear out the tires, that's all there is to it. Really..the only reference you have as to which compound is correct is what works the best, regardless of what car or class you're running.
#1821
Aaron what body do you run on your nitro and electric trucks and why? Thank's for the info
#1823
Are there other bodies that fit the XXX-BK2 series than the single one produced by Losi?
What about the XXXT-MF2? My truck body has taken a tremendous beating and only strapping tape is keeping it together.
I was searching for a different look to both my BK2 and MF2.
Thanks.
Thanks.
#1824
Check out www.jconcepts.com for some cool bodies. Jason Ruona and Jim Myers are responsible for some of Losi's bodies..they make good stuff. Their Illuzion line of bodies is dope.
I run the stock MF2 and AD2 bodies on my trucks. The MF2 body just works better than any of the other bodies I have run; it is much more stable and speed and easier to drive in modified. The new AD2 body isn't nearly as exotic as the MF2's J-Lo body, but it is very neutral and gets the job done nicely .
Casper - I'll check on it..thanks!
#1826
Tech Prophet
Thanks.
Thanks.
#1828
Hahaha...oops!
I saw Adam's post on TTT..
#1829
Aaron,Have you had any prob. with the screws in the hub?
#1830
Hey Aaron,
I've been trying to get ahold of Trinity about warranty and they won't respond. I have followed their direction at their website. 5 emails over the last 30 days and nothing. Any ideas?
john
john
