Advanced Electronics Black Diamond ESC
#961
Hey guys my computers hard drive crapped out ...I forget where to get the programming software can anyone help me out ?
#962
#963
Ok thanks geez I'm not sure which is which ....I don't have the latest software where you can't change the software yourself now ....I have the one before that is that version 2 u think?
#964
Also is this software mac compatible.?
#965
Do you need a battery connected to your speedo for the tuner to reconize it!!!
#966
ok so i have the cable connected to the speedo i have the other end of the cable connected to my usb why why why does it tell me it cant connect check cable it says or check connection ...everything is connected!!!!
#967
You need to unplug the ESC from the receiver and plug a battery pack into it.
#968
Thanks it's been a while and my harddrive on my laptop just shit the bed ....so trying to get everything on a new computer ....I think I was able to just connect a battery to the car and program it like that....but I could be wrong
#969
#970
yes you just plug it into the sensor port and turn on the switch. no unpluggin of the receiver. just did mine last night changing drag break. make sure you get the ding ding when you plug the wire in so that windows gets that first before you plug the wire into the sensor port. all 3 lights light up if working right as far as I know.
#971
hey Nash, i was working with mine monday night, and i have to unplug it from the receiver or it won't connect to the computer.
i think it depends on what brand radio/receiver you're using.
#972
I use sanwa and don't have to disconnect the speedo from the receiver, I know other that use the spectrum 2.4 and have to disconnect from the receiver.
1. plug in usb lead to pc and speedo ( disconnect speedo from receiver if not using sanwa)
2. connect lipo to speedo
3. now open GUI on desk top and select com port and select read all then click connect.
#973
Hey guys today i noticed that the first quarter inch of pull on my transmitter offers zero throttle in the car....is that an adjustment on the speedo to get the car to move the instant the throttle is touched or is that a function of my transmitter?
#974
There is a small dead spot on mine as well, but certainly not 1/4 throttle.
Reset the throttle EPA's etc on your radio and then recalibrate the ESC.
P.S. Loving the new 3.5 firmware in boosted
Skiddins
#975
what are the differences on the new firmware 3.5 compared to 3.4b?
in 3.4b I did not like the brake, gave me no feeling, much better than the 3.4
where can I find the firmware 3.5? I have to ask Per ?
thank's
