BMI Racing "Copperhead 12" discussion and support
#617
Here is my setup.
Front:
3.5mm ride height
2x pink front cut to 1.650 w/ glued side walls
1 degree camber
6 degrees caster(2 shims to rear of arms)
#5 shur lube in front damper tube
.75mm droop
angled servo w/ no bumpsteer
stock roll center
stock flex plates w/ set screw in short position(stiff)
Rear:
Gold center shock spring w/ 50 wt. oil (may try blue)
#3 shur lube in tubes
3.5mm ride height
1mm pod droop
Gray/white(same as jaco orange) cut to 1.700 and glued side walls
1.2mm carbon fiber flex plates(stock will be fine) mounted long
Pod level
172mm track width
Front:
3.5mm ride height
1 degree camber
.75mm droop
stock roll center
Rear:
3.5mm ride height
1mm pod droop
Pod level
172mm track width
#618
Can't wait to get mine!
#619
Let us know when you guys will be there practicing so I can see the car in action
#621
Here is my setup.
Front:
3.5mm ride height
1 degree camber
.75mm droop
stock roll center
Rear:
3.5mm ride height
1mm pod droop
Pod level
172mm track width
Front:
3.5mm ride height
1 degree camber
.75mm droop
stock roll center
Rear:
3.5mm ride height
1mm pod droop
Pod level
172mm track width
#624
Okay, so with a 10.5 there could some minor adjustments but it is a good basic set-up for sure... Thanx, will try it when I have mine... When I have a set-up I will post it here and maybe something for the BMI website...
#626
GM75 G2... And if that one is not here in time I will use the GM120 G2 for the time being...
#628
The GM speedo's are together with the Tekins the most populair and most udes ESC's over here. Most guys in TC stock 13.5 and Pro10 Stock 10.5 use them as well as in 12th scale in the fall/winter. Both of them really are performers...
#630
