BMI Racing "Copperhead 12" discussion and support
#2371
well i ran yesterd day i had a little more luck got 45 laps. I tried a lot of changes and practiced alot but i just cant get this car to rotate. And scrubing to much speed in the turns.
Front :
12r5
.20 springs
1 camber
magenta with 1/3 sauced
42mm trued edges not glued
flat servo
.5 deg toe out
caster is thick shim in front thin in rear i think thats 3.25
4mm ride height
167.8 width
Rear
Shock mount in center holes
Medium ball stud
60wt oil
Blue shock spring
Shurlube 3 in tubes
1mm pod drop
pink rears full sauced
43mm
171.3 width
I tryed gold spring but didnt help i tryed more and less caster but didnt feel as good. tryed orange rears but then i didnt have the rear grip. i tryed thick shock oil and that seemed to help some. Also tryed stiffen the rear links to short hole but then didnt wanna turn had turn dual rate up about to almost 70. i thought maybe was me and let the real fast guys drive it and they still where almost sec slower then theres
Front :
12r5
.20 springs
1 camber
flat servo
.5 deg toe out
4mm ride height
167.8 width
Rear
Medium ball stud
60wt oil
Blue shock spring
Shurlube 3 in tubes
1mm pod drop
43mm
171.3 width
#2372
Is there a conversion kit for the original 4cell car to the current copperhead12?
#2373
Front :
12r5
.20 springs
1 camber
flat servo
.5 deg toe out
4mm ride height
167.8 width
Rear
Medium ball stud
60wt oil
Blue shock spring
Shurlube 3 in tubes
1mm pod drop
43mm
171.3 width
Front :
12r5
.20 springs
1 camber
flat servo
.5 deg toe out
4mm ride height
167.8 width
Rear
Medium ball stud
60wt oil
Blue shock spring
Shurlube 3 in tubes
1mm pod drop
43mm
171.3 width
Edited to add: I also would recomend going to 1 1/2 neg camber and slightly reduce the reactive caster, try these in stages.
#2374
im running a blue center cause i thought softer spring would give more grip with the oranges. So does a softer or harder center spring keep the car planted
Also i drove a few cars with side springs instead of flex links seem to rotate better but there was still planted. Alot of guys with 12r5.1 and griffins and crc all are running mag pink with no issues. im try few more things maybe get it might try double dbl pink fronts since magentas i barley have to sauce.
#2375
If the traction is decent, i would glue the sidewalls up front. Run maximum caster w/ the blocks at 5 degrees of reactive caster. Run the shock in the shortest postion on the chassis that will allow for 2 screws to mount. Run the 1.2mm flex plates in long postion. Add camber to pick up some steering. Try going to 1.5 degrees of camber. Camber is a huge adjustment for adding steering. Too little camber for a given setup will make the car push bad and feel like it is not rotating. .020 front springs work great and make sure you put #3 shurlube on the kingpins and shim the kingpins to have a slight bit of droop.
If you are running 13.5 boosted, stick with the pink rears but if you are running 17.5, Your tire combo is hurting you. For 17.5 Blinky I would go with Orange rears and gray fronts. Hope this helps.
#2381
If you have a decent number of guys running, the grip should come back up pretty decent after a day or 2 of running. Once you find a setup that works for you, you wont need to veer too far from it. Slight changes for each condition will be all really.
#2382
17.5 blinky Alright thanks so much i was just tryng run the tires i see everyone else running thats ahead of me lol. But they are running different cars also. Ill get a set of grey and yellow crc in and try it out. Also im running a crc r8c body just to add a lil info.. So does a stiffer spring or harder spring add grip to the rear end???? Tryin do it on my own and looking at others have on there cars but dont really know what im doing......
#2383
17.5 blinky doesnt really need a high rubber content tire. I dont know your track conditions but i normally would never run anything other than synthetic tires for 17.5.
Softening the center spring does increase rear traction. The down side is when the bite comes up it can make the car darty also. I found this out at our local track. I always seem to settle on the gold. This is AE springs of course. I know CRC spring colors are different rates than AE.
What you need is to try the suggestions i made and see if they work for your track. Let me know the days and times you go to race and maybe we can set up a phone conversation while you are at the track to walk you through changes. We want to get you up and running and your setup where it needs to be so you can be competitive. You will get there buddy.
#2384
Jason,
Can parts for for the older cars DB 10R and DB 12RR be ordered?
