Plus 7
Plus 7
Anyone know the factory settings for this thing? Someone gave me one and I am having troubles getting it running. It might just be messed up, but I want to give it a try. Thanks
Base Carburetor Settings: One turn out from flush on the top and 2.5 turns in from flush on the bottom. For breaking in the engines turn out ¼ turn from base settings
Set idle speed air gap @ ~ .7mm
Your HSN will likely end up leaner than that; but this should get you started.
Seeing that the HSN was 3 turns in and the LSN was about the same it makes sense why this thing was off. THanks
