i need help plz >
i need help plz
i need help plz
Old 03-02-2010, 03:16 AM
Default i need help plz
Ok so i accidently striped a hole in my crankcase (one of 4 that holds the head on) on my o.s. .18 engine . but since there are more threads down in there all i need is a little longer of a bolt. the original is a C.M2.6x12. does anyone know where i can get a little longer one? or maybe buy one from someone on here. even if i have to cut it a bit or use small washers..............
bmx1077 is offline
Old 03-02-2010, 03:41 AM
Just take the original to the local hardware store. I'm sure someone there will help you find what you need.
Jamie James is offline
Old 03-02-2010, 05:33 AM
ok ill give that a try today but if i cant find anything there what should i do from there?
bmx1077 is offline
Old 03-02-2010, 10:23 AM
You can measure it, then go to www.towerhobbies.com or www.amainhobbies.com and order one that is slightly longer than the one you have. Thats what spidey would do
Kyo83 is offline
Old 03-02-2010, 11:03 AM
Turbo9000's Avatar
Support your LHS! any good LHS will have an assortment of metric fasteners for this occasion!
Turbo9000 is offline
