Kyosho TF-6
#541
I see kyosho didnt do so well this past weekend ...bummer....anyways for those of you running the 2.0mm top deck are you cutting out that extra piece at the front?
#542
ordered the wrong knuckles so if anybody needs knuckles for there tf6 let me know.....i havent taken my wheels off but it looks like they might work on the sp....unless i missing something.
#544
#545
So let me see if i got this rite....so i got my tf6 arms today and im going to put them on just want to get the suspension blocks rite so i have 4 c cups which im gonna use on the front....outers c out and inners c in....for the rear i have inners E in and outters im looking for 2.5 degree of toe in would that be the B block? .....is there a chart that i good use to figure this out?
#546
as for the suspension chart here you go
#547
Thanks.....have i mentioned how wicked this thread is in terms of support yet !!!......also what are you guys using for front rear?.........and wheres that chart from because in my manual i have REAR front c in and rear back e out and that gave me 3 degrees of toe in and the charts says that would give me 5 ? HUH
#548
Sorry forgot to say that ;-)
#549
#550
Here is the one for the rear of the Lazer ZX5(FS) series: http://www.petitrc.com/setup/kyosho/...Sus_Holder.pdf
There is a P/N from the TF5, so hope should be good for the TF6 series.
#551
Thanks afno seems like its rite....so now by using the tf6 arms with rear fronts c out you cannot acheive more then 1.5 of toe no matter what blocks you put in the rear rears.....do i need the rear fronts to be c out to use these arms?
#553
Ok that makes more sense ...will do ......thanks!....but what im trying to figure out is what you are using for front fronts and front rears.....are you keeping at a neutral 0 or are you guys giving it some toe out or arm sweep?
#554
vasco's setup is a good starting point: http://www.rctech.net/forum/11062825-post434.html
#555
neutral for me!
