MUGEN SEIKI MRX5
#62
#64
#65
newer car better
Mugen is a racing company so it's safe to assume the new car is better + mugen has a history of holding off on new models not unless there is a significant improvement...
MRX4 is a whole lot better than the 3 so I'm guessing the new car will also have a noticable improvement over the 4....
#66
You are missing the point.
Let’s go back 15years to when Associated had the original RC10 tub chassis. They did 2 World Championship with proto-type chassis and never released them and then finally released the B2. Why, because the proto-type chassis only out performed the standard tub chassis on certain styles of tracks. Maybe the MRX4-R was the same and only work well on few types of tracks. We still use the MRX4-R chassis and hubs from the rear. That’s 2 improvements that came out of the R that we still use.
Mugen can’t test the car on all tracks before it’s released, other wise all of us will be saying “can well have one to test on our track”. Lets be realistic a CAD design and the real thing can be two different things. Does their software take into count plastic flex, track temperature, setups and drivers ability. I don’t what degree Robert Pietsch has in engineering, but from his past project and Koji Sanada knowledge the MRX5 will be special.
I believe out of all the manufactures, Mugen has had to do the least amount of redesigning after a new chassis was released. The last major problem I recall was at the Australian 1/8th World with the MRX3 tank. Mugen Seike where good enough to arrive at the worlds with modified radio tray which fitted the old and proven MRX2 tanks.
Interest that your signature has the word Kyosho in it?
#67
I will disagree that just because it new that it means it better Muegan made the mrx4 which was a very good car, I owned one then then made the mrx4r so your assumption is newer better, but it wasn't what prove that is they went back to the mrx4 and made it mrx4x with some improvements ecentric hubs and other things back to shorter shocks
The Mrx4, r, and x are basically the same car with in different stages and could have been upgraded with a few parts. In mugen's history from the Sedans 2,3,4 and same with the 1/8th.. Once mugen designates a new # 3,4, and now 5 usually comes big improvements in performance and ease of maintenance....
Don't you think there was a big improvement from MRX3 to the MRX4?
#68
Even with the X, many drivers like to use R parts for certain conditions. R rear uprights can often be found on X's. I liked the R front shock tower.
None of these were complete new cars. They were just the original 4 with a few new parts. If you had already found a really good set-up for your track with the old car, the new car might not improve it. If you were having some small issues with the older version, the new version might have been just what you needed to find that balance.
Bottom line is the track record. MRX-3 was better than the 2. 4 was better than the 3. Same holds true for the TC's and the buggies.
#69
newer is better
#70
Can't wait 2 attach this 2 my signature X5 is gonna be outstanding believe me I can smell it 4,000 miles away
#71
I wished they used one bulkhead for the rear shaft and 2-speed shaft, it is a proven system and even Kyosho can win WC's with such an "old design".
As mentioned by me before, this 2-piece rear end has some issues and fixes with the Velox and 966 that I do have some thoughts about it. I can only hope Pietsch has learned from it and made adjustments to this design.
Oh well.... If RickV will have one of the first produced cars I will take a look at it.
#72
Well its just a matter of time now before the x5 hits
#73
CAD dwgs are up!
Mugen Seiki has posted the CAD drawings. Time to start the countdown clock until these are on the shelves.
http://www.mugenseiki.com/menueefi.htm
