MUGEN SEIKI MRX5 >
MUGEN SEIKI MRX5
Like Tree3Likes
MUGEN SEIKI MRX5
Old 05-30-2013, 04:17 PM
  #2626
walo's Avatar
Originally Posted by brothainchrist0
Hey guys, i'm having some issues with my mrx5. I need more braking before the turns and at the end of the straight. In my 10th scale I put a front diff in the car and it added so much braking but I was told there is no front diff for the mrx5? I have my brakes set as harsh as I can get them without it spinning out and its definitely not enough. It spins out real easy if I jam on the brakes any more than I have it set right now. What do u guys suggest?
Thanks!
Kyle
Go through your radio and try the a.b.s feature.
walo is offline
Old 05-30-2013, 04:38 PM
  #2627
nitrodash's Avatar
My mrx5 is a little weak on the braking I learned to just drive with it I was thinking option parts but I've Gotten mixed reviews about the Hopup brake pads some say the braking is weaker with them some say braking is stronger so I'm up in the air about purchasing the option pads but just driving has fixed the braking issue somewhat.
nitrodash is offline
Old 05-30-2013, 05:40 PM
  #2628
brothainchrist0's Avatar
Trader Rating: 145 (100%+)
Awesome. Thank you for the pointers! There is still that extra spoiler I haven't put on the body yet so that might help with the downforce. I need to get a tire truer that will true with camber so I can get the right tires on too. My truer is just straight across.
brothainchrist0 is offline
Old 05-30-2013, 05:44 PM
  #2629
choisan's Avatar
I used this one, www.101racing.com, there is an item called bullet proof.....
choisan is offline
Old 05-30-2013, 06:26 PM
  #2630
Crap, looks like I have some more learning to do. I am not familiar with the abs system in the radios
Old 05-31-2013, 05:10 AM
  #2631
ralphierace13's Avatar
I see the brake pads but how the hell do u order from that site!!
ralphierace13 is offline
Old 05-31-2013, 07:24 AM
  #2632
choisan's Avatar
I ordered from pro futaba Japan
choisan is offline
Old 06-04-2013, 06:57 PM
  #2633
MrHistory's Avatar
what you couldn't figure out that site Ralph?
Japanese websites are funny...
MrHistory is offline
Old 06-04-2013, 09:47 PM
  #2634
JJ's Pre- World MRX5 WC set up for those of you interested.
http://www.jjwangracing.com/setup-sheets-nitro/
rwang is offline
Old 06-05-2013, 03:52 AM
  #2635
disappointed that masami is not racing, neither hara
toto is offline
Old 06-05-2013, 04:04 AM
  #2636
Anyone know where is possible buy parts, and have now really disponible its, for WC Spec?
toto is offline
Old 06-07-2013, 01:25 AM
  #2637
Default Difference between std (2401) and HT (2410) chassis?
Does anyone know what the difference is between the new WC spec chassis and the Std MRX 5 one?
karlfawcett is offline
Old 06-07-2013, 06:19 AM
  #2638
Pooh2's Avatar
The newer Chassis is harder and has less flex than the older Chassis.
Pooh2 is offline
Old 06-08-2013, 01:26 AM
  #2639
sm4100's Avatar
A well adjusted A.B.S is all you need, it can brake any 1/8 with easy you just need:
1. A strong and faaaaast servo, slow servo does not get the job done and will overheat
2. If you can adjust the ABS point on your transmitter try these:
a. Adjust your mechanical brake until it starts to lock the wheels at the end of a straight full speed than jam break
b. Switch on the ABS or ALB depending on your transmitter
c. Adjust the stroke to 70%
d. Brake point to 85%
e. Release 0.04 s
f.Hold 0.04 s
g. Lag 0.00 s
The whole brake system is std on my MRX5 but the break power with ABS is amazing
All starts on your servo speed and the best and strongest I have tried so far for ABS purposes is KO Propo, many others will burn soon with above setup.
sm4100 is offline
Old 06-08-2013, 03:24 AM
  #2640
Roelof's Avatar
ABS does not work for everyone. The one loves it and the other looses the feeling in the brake as he has no control over it.
It is not what you need to use but something you have to try.....
With my MRX4 I switched back to a very old and proved system, an epoxy brakedisc on plain steel brakepads. It is very stable in braking and went from a 13 gram to a 3 gram disc.
Roelof is offline
