ring and pinion grease. >
Old 01-27-2010, 05:07 AM
Originally Posted by Tony Newland
Just in the CVD part..... if your car has them
not really.... I clean/lube them every few races and havent had any issues
Im not sure if they are cvd or dogbones, they have a pin on the end that just rides in a u shaped cup that is attacthed to the diff.
cassidy is offline
Old 01-27-2010, 06:27 AM
Integra's Avatar
Grease on CVD's is imo not right unless you have specific boots to keep said grease clean and or using a dry file lube of some sort.....Dirty grease isn't helping the wear factor when you have grit and grime mixed in with the grease....its basically like sandpaper to the CVD.
Integra is offline
Old 01-27-2010, 10:19 AM
mblgjr's Avatar
Trader Rating: 86 (100%+)
Dupont Teflon dry-film or SuperLube PTFE/Teflon dry film for exposed joints:
http://www2.dupont.com/Consumer_Lubr...s/dryfilm.html
http://www.jamestowndistributors.com...?pid=4008&BASE
Pretty much any automotive chassis grease will do for the ring gears. I use Mobil1 just because it's what I keep on hand for automotive use anyway; but again, any will do.
mblgjr is offline
Old 01-27-2010, 04:05 PM
Peter Martin's Avatar
Trader Rating: 12 (100%+)
The Eureka Lube is made for RC car ring and pinions. The choice of Adam Drake, Mark Pavidis,Chad Bradley,Ryan Maifield,Ryan Lutz etc.
http://tkocompetitiondev.com/product...roducts_id=343
Peter Martin is offline
Old 01-27-2010, 05:42 PM
  #20
Trader Rating: 61 (100%+)
bel ray allweather grease ..a tub lasts a lifetime
http://www.belray.com/consumer/product.fsp?pid=1326
zixxer is offline
