Capricorn LAB-C01
#661
To me the risk of blowing a servo or receiver just isn't worth it.
The Xceed regulator is perfectly reliable, have been running mine for two years, and it is very small and light weight.
#662
revised
can somone help me out? I cant find wher the revised manual online. I looked on capricornrc.com but nothing there
#664
http://www.capricornrc.com/LAB%20C01...0rel%201.3.pdf
I will check with Capricorn if they can place a link to the download section on the Lab product page.
http://kamikazercracing.com/proddetail.php?prod=LABC01
#666
Hi everyone
I sold my NT1 and I'm assembling my new LAB.
DS, you are the guilty
I found some little problems in the assembly, but nothing important.
Hope will be a fantastic car on track. I'll keep you informed.
#668
I'm in the process of my assembly can u share what you hav come across so I can look out for this?
#670
Well... my english is very bad.
I found nothing important, just 2 roll center plastic inserts (rear lower arms) hard to put in the aluminium.
Front lower arms very nice with the ARB, but to get a free movement, I had to sand just a little the lower arm, the round part where you insert the screw with the arb mount. The 2 pins from the lower suport bumper, I had to sand 0,2 mm.
Finally, I had to sand again the shims used to setup the offset. A had 2 shims 0,6 + 0,6 mm for each wheel. Just in the front train, that was too much. I sand them to 0,5 + 0,5. That was good to get the bearins rotate smooth. In the rear was no problem, so I put 0,6 + 0,6
#671
Step 1.0 Shockabsorbers
Shock absorber length, for me it was impossible to get the shocks to the 59/60mm length.
If I want to set them to 59/60 the ball end was almost completely off the shock shaft.
I ended up setting the fronts to 56.5mm center to center length and the rears to 58.0
Step 10.0
The manual states that you have to insert a ball bearing into part number two, but there is no room for this bearing.
I guess this is still from the first kit’s when part number two was still alumunium instead of the plastic it is now.
#672
Yes! same I found with the shock absorber length. Impossible 59/60 mm length.
Also, the manual talks about 7 different roll center positions, and with the black inserts, I found just 5 positions.
And the M3 screw that comes in the clutch bag is too short
Despite this little things, the car looks amazing
#673
TMF made some very nice pictures during the build of his Capricorn Lab.
This is the link:
http://picasaweb.google.com/11692313...NnsxN6OhvjCBg#
It also includes some pictures of the various parts being weighed on a scale and compared to some NT1 pieces.
This is the link:
#674
Thanks DS
Another thing... my kit came with 550 oil for schoks and 150k for front differential. Maybe they are updating??
