Capricorn LAB-C01
#363
Attached is the English version of the Table.
Regards
Regards
#364
instruction "ARB" front
#366
Hi, some setting for a track with low traction?
#367
Same shore tires all around, instead of one step harder rear.
Less camber front 1-1.5 rear 2.5-3
Rear camber link longest
Lighter rear diff(40k) and front diff(80-100k) or front solid axle depending on how you like.
More rear toe in, about 3.5
Less caster
Lower roll centers
Smoother clutch
Add side dams on your bodies wing
With these changes, your car should have more grip, and be smooth, easy to drive in low traction. Remember that you should change the settings one of a time to understand exact feel of every single adjustment.
Less caster
Lower roll centers
Smoother clutch
#368
Less caster
Lower roll centers
Smoother clutch
Less caster
Lower roll centers
Smoother clutch
#369
Capricorn released a solid axle, its in the shop now.
#371
capricorn life battery
hi
May i have the dimensions of the capricorn life receiver battery ?
in mm
Regards
G
in mm
Regards
G
#372
EC warm Up Setup Sheet from the winner (Martin Cristensen)
see attached
see attached
#374
#375
