Edam Spirit 10th Scale >
Old 09-02-2012, 11:22 PM
  #181
Bundy_Bear's Avatar
Trader Rating: 11 (100%+)
Originally Posted by richardc7696
Yeah, the capricorn clutch has been good. I found that the original edam clutch was a bit inconsistant. I'd be keen to hear what u think of the new edam clutch ma racer
Oh my goodness he found Rctech and i am not the weird person anymore that talks about his brother:O
Andrew
Bundy_Bear is offline
Old 09-07-2012, 08:34 PM
  #182
Default Team Pursuit is Back to Business
Hello all
This is Terry from Team Pursuit Racing
I am back in Business and try to help EDAM to make out he's products too the USA and Brazil Market one more time if you need to contact me
Phone: 818 398-6112
pursuitspt1 is offline
Old 10-22-2012, 02:45 AM
  #183
Bundy_Bear's Avatar
Originally Posted by ma racer
anyone tried the new clutch or the upper deck conversion? Mine is on its way. In correction to my previous post, the clutch is more than just a harder spring, it contains a new shoe compound and new bell as well.
MA Racer:
Any updates on the new clutch and radio tray? Richard isn't too far away from a 16 lapper if he can get a clean run.
Has anyone tried different shock pistons? I notice the latest batch of kits comes with a green spring and now included springs between the brake shoes which is a move in the right direction.
Look forward to hearing from you!
Andrew
Old 10-24-2012, 10:28 PM
  #184
Bundy_Bear's Avatar
Default New Parts
Some new parts thanks to Joe at JPM Racing and his great service
Alloy Front Sway Bar Mounts
New Clutch (Harder Spring, High Grip Clutch Pad & New Clutch Bell)
New Front Steering Hubs
One Piece Engine Mount
Andrew
Old 10-25-2012, 03:53 AM
  #185
Bundy_Bear's Avatar
Default New hubs and front sway bar mounts installed
Front hubs seem to reduce the play in the drive shaft backwards and forwards
Lots of gold bling
Old 10-25-2012, 04:33 AM
  #186
richardc7696's Avatar
Looks good Andy
richardc7696 is offline
Old 10-25-2012, 04:51 AM
  #187
Bundy_Bear's Avatar
Looks good Andy
Its much better then the 3 Racing sway bar holders. Only gripe, the grub screw is on top now and in car shocks is in way of getting 1.5mm drive into screw
Did you get everything ready for tomorrow night and on the setup station to check the rear end of your car?
Andrew
Old 10-25-2012, 06:12 AM
  #188
Yeah i'm all ready. I sorted the rear end out.. i think
Old 10-25-2012, 07:05 AM
  #189
blis's Avatar
Andrew
Get your sway sorted before you put shocks on Andrew..
Working tomorrow evening.
blis is offline
Old 10-25-2012, 04:08 PM
  #190
Bundy_Bear's Avatar
No probs
Old 10-25-2012, 04:10 PM
  #191
Bundy_Bear's Avatar
All you had to check was camber
Old 10-31-2012, 11:25 PM
  #192
yeah, but i would adjust the camber and it would show 3 degrees. So then i'd adjust the other side and check both sides again and it would be different on the side i've just set. I dunno if the Hudy set up station does the same thing, but the 3racing one is frustrating to use.
Old 11-01-2012, 02:54 AM
  #193
Bundy_Bear's Avatar
Just press down on the car and let it reset and see what difference that makes, but what would i know i can't even do wheel nuts up right!
Old 11-01-2012, 04:05 AM
  #194
blis's Avatar
Or best we say... "Richard is driving the wheels off it nowadays!"
blis is offline
Old 11-01-2012, 04:49 PM
  #195
Bundy_Bear's Avatar
Richard: Thinking MissMoo R/C should of gone G4JS, then when you have it flying through the air again the flying wing arms are desgined to fly away from the car on impact
