Durango DEX210 Thread >
Like Tree80Likes
Old 12-03-2013, 08:44 PM
  #13006
Lead-Lobber's Avatar
Location: Currently live in southern AZ, or closer to northern Mexico if your a realist.
Thanks Flame. I do have a question, and 867 pages is a LOT to sort through so maybe some help would be nice.
What parts are needed to convert to MM? I didn't get any additional parts with the RTR. I'd like to have a RM and a MM ready for what ever track conditions call for. I will be running outdoor dirt/clay at Hobby Town and a clay (I believe) indoor at Competition Hobbies.
Lead-Lobber is offline
Old 12-03-2013, 10:08 PM
  #13007
ekt
ekt's Avatar
Since you didn't get any additional parts, here's what you'll need.
BUMPER & REAR TOP DECK SET TD320121 (just for the rear bumper, not necessary)
WING MOUNTS TD320126
REAR CHASSIS BRACE SET TD320127
A couple 8mm and 20mm m3 screws
If you're planning to run MM4, the most common MM setup you'll also need
IDLER GEAR SET TD310238
IDLER GEAR PIN (2pcs) TD310247
SHIM 5x8x0.5mm (10pcs) TD709033
2 5x10x4 bearings
ekt is offline
Old 12-04-2013, 02:56 AM
  #13008
Trader Rating: 38 (100%+)
Hoping I can get some advice on my mm4 setup. I got the car used and ran it and it hooked up ok. Decided to service the diff, opened it and it was half full of an unknown fluid. I cleaned it out and refilled with 70 weight Losi shock oil which is what I previously had used in another car. Well now the car pushes, on and off power and the rear breaks loose on power. Running on a carpet track, stagger ribs front and mini spike rear. What did I do to the diff to make the change so drastic? Someone at the track suggested 2k diff fluid, is that something I should try? HELP! Lol
vw addict is offline
Old 12-04-2013, 05:24 AM
  #13009
Default Thanks!
2 5x10x4 bearings
Thanks EKT! That is the info I was looking for! The car I just got from Shagino will be coming with the MM parts, but I'll need the screws. SWEET LAWD!!! I can't wait to get this thing out on some sweet jumps... LOL
Old 12-04-2013, 07:13 AM
  #13010
Trader Rating: 29 (100%+)
I run mm4 on carpet and use 2,000wgt in the diff and it is dialed. My full setup is on post 12452
Walkman is offline
Old 12-04-2013, 09:31 AM
  #13011
Cool, I'll check it out, thanks
Old 12-04-2013, 10:01 AM
  #13012
Trader Rating: 84 (100%+)
If anyone is looking for a dex210 pm me I have 2 that I am going to be putting up for sale.
jeff jenkins is offline
Old 12-05-2013, 02:17 AM
  #13013
More pics of my DEX210 during at it's latest race day
syntex1 is offline
Old 12-05-2013, 03:37 AM
  #13014
LoudOne's Avatar
Trader Rating: 36 (100%+)
Good morning! I'm looking into possibly getting the Exotek +8 carbon chassis and currently have the stock chassis w/ JConcepts "Finnisher" body set up rear motor. Will I have to get a new body to compensate for the +8?
LoudOne is offline
Old 12-05-2013, 04:01 AM
  #13015
Trader Rating: 57 (100%+)
No. Only the Dimec chassis requires a new body due to shape. With the +8/10/11 using side pods, the shape is the same withheld front being lengthened. The cut outs for the deck bushings will be a bit further back though.
shagino is offline
Old 12-05-2013, 06:18 AM
  #13016
Speed is Key's Avatar
Location: Born in Simi Valley CA ... Raised In Temecula CA ... Live in Louisville KY ... BUT I WILL BE BACK IN CALI SOON (:
Hey guys I need help !!! Whats the best 17.5 motor to run stock on a DEX210 on a nice indoor clay track ? Thanks any help is appreciated
Speed is Key is offline
Old 12-05-2013, 06:22 AM
  #13017
Trinity Kills Shot, Rev Tech, Reedy Sonic 2, Schuur, Pick any of the big names they are all good. I currently run Trinity motors.
Walkman is offline
Old 12-06-2013, 06:33 AM
  #13018
Default the B chassis compatibility issues
Hey guys,
More info please...
I broke the kick up on my one piece chassis. So I ordered a new one online, got it in and swapped all my parts over. When I did so, I noticed a few things.
1, I ordered the B style chassis. Evidently, my parts are not the new B style.
2, The front bulkhead did not sit flush with the bottom of the chassis. The chassis is sitting the thickness of the chassis below the bulkhead. New B style front bulkhead?
3, The rear of the B style chassis does not have the cut out for the rear motor guard. Two options? Dremel the chassis to fit, or is there a new B style motor guard?
Other than that, installing the new Diggity Design shock towers, steering drag link and RDRC shock stand offs went as planned. Just need some pillow balls for the shock caps...
Any help is greatly appreciated. Cheers.
Jeff
Old 12-06-2013, 07:07 AM
  #13019
Hey guys,
More info please...
Jeff
Yeah, that was a problem that guys were having with the DIMEC chassis. Some solved it by using skid plates, others used aluminum.
- Correct. The front bulkhead/RR hanger/Motor guard all need to new parts to work.
- So far only the TD plastic bulkhead works.
- New B style motor guard. Dremeling the chassis will likely bring back the weakness it was meant to solve. A lot of people had breaks on those rear tabs.
http://www.team-durango.com/part-inf...artNo=TD320227
shagino is offline
Old 12-06-2013, 07:18 AM
  #13020
Thanks for the info Steve. I clicked the link and then it dawned, that is what they were showing me with the paper that came with the chassis.
Hmmmm.... What to dooooooo. LOL
Know anybody with an aluminum chassis for sale? bwahahahaha.
